ADBTuner: Create Channels, Custom Config and CDVR Custom Channels for DirecTV
I tried v7.0 but it was showing the scren right as the channel launched on the app so went to 6.0 and it launches perfectly.
Video starts after is is going.
For me, with animations disabled, both @anon38303228 configs v6 and v7 are briefly showing the DTV app home page before tuning. Both are tuning in the range of 10-11 seconds.
look forward to your need for speed being applied to these and hopefully ah4c.
i'm sure you'll see the setup posts for them, detailing turning off animations for these too.
edit; this process in ah4c w/ osprey seems slow, but i've never made time to see if it could be faster.
Just updated my config and it looks good.
Thanks for disabling stuff and making things work so well.
I just tried v7.0.1. First tune was 15 seconds. Subsequent tunes 5 or 6 seconds...
That must have been what I noticed on the first tune after I had been playing with other config files.
Bad deeplinks will only happen if I'm typing them in by hand, or make a mistake in copy/paste. (I have been there and done that many times) If I'm using Project One-Click to set things up, there is much less chance of operator error.
As far as a subscription to DTV goes, I'm sticking with my base Genre package of MyEntertainment ($35/mo) with the MyCinema add-on($10/mo). That adds up to half of what I was paying for YTTV.
Through the holiday season, I can have four of my local networks for watching parades and holiday specials, by adding the MyNews base package (a ripoff at $40/mo). BUT, at least that can be added or deleted as I desire. I can mostly live without it.
It stinks that there is no financially reasonable way to get local channels in areas with poor OTA reception.
Nice! There have been times in the past when the only thing I could do to save it from a bad tuning crash was to remotely power cycle the device, or run upstairs and reset things manually. This will save me some frantic runs up the staircase. :laughing: I appreciate all the work you have put into this project.
I look forward to hearing about your experience with the Osprey devices. Have fun with them!
I'll give it a try. Do I need to change all of my DTV channels to this config for it to work properly? Or, can I apply it to a few of them just for testing?
Is there an easy way to change the config on all of my DTV channels at once? I suppose that I could run the Project One-click action again. But, I kinda hate having to pull the curl command channel list every time I want to swap configs...
When i first tested the config, it took a while becuase the app propbably needed to be relaunched.
I clsed the stream and fired it up and it was nice and fast due to the app being warm and open.
Thanksk for letting me know. I went in and put it back in place.
Hopefully the configuration will survive the update that is coming out for mobile and tablet.
I'm glad it all works.
I'm having a real problem getting this setup do to something i'm missing due to lack of eye site.
Any way to get this added to one click or set all this up without portainer.
I'm experiencing an issue with the static file server where the process didn't go away when i removd the docker.
I like the tool and would appreciate just being able to generate the json.
I have Portainer installed on my Synology and have tried installing things but just seem to be running in to problems.
I can try again.
Actually, I believe we can pretty safely assume the value people specify for PORTAINER_HOST can be used as reasonable default for ADBTUNER_HOST (and in one or two other places). It'll still be possible to change it of course, as it'll look just like it does now, but with that value as the default instead of using my host value.
This is done, and was pushed moments ago as bnhf/olivetin:latest (aka bnhf/olivetin:2025.12.15).
2 posts were merged into an existing topic: ADBTuner: A "channel tuning" application for networked Google TV / Android TV devices
Used the One click for the creation of this with osprey, fails to tune for me right now.
Not sure where the logs would be or where to check
The 'view' with the buttons for remote controls does work
Please post the ADBTuner Portainer-Logs for the failed tune. There's a Quick Actions button in the Portainer WebUI for that purpose.
We need the actual log text from a complete failed tuning cycle. Based on what little I can see in this screenshot, it appears you have no virtual tuners available. If you only have a single tuner encoder, you'll see that fairly often, especially if you're trying to channel surf.
