Adding Playlists to SideBar Navigation
When I try to add a new Playlist to SideBar Navigation in Global Client Settings, app will no longer start in FireTV. When I remove the Playlist, it then loads again normally. Any suggestions on error?
Are the playlists working properly on the firetv?
I have created a couple of playlists and added to the sidebar the same as jb7764. My app still works but I cant see the playlist anywhere.
This will be very useful when I get it working!
Edit: I just fired up an AppleTV I rarely use and the playlist shows up on the sidebar and works great. Must be a bug in the fitetv?
Android TV app does not have Playlists support, though adding a section to the sidebar should not crash the client.
We'll look into this.
Oh, okay. Bummer!
