I just had the thought: what if library collections that use smart rules, or advanced passes could be saved, shared, and imported in a similar way as Home Assistant blueprints?
This way, if somebody asks: "what is the best way to set up an advanced pass for this or that?" you can just answer: "Here's a blueprint for it". Just import it and be done with it.
Right now, there is forum section to share ideas for advanced passes:
Latest Playground/Advanced Passes topics - Channels Community (getchannels.com)
But what if we could go a little further and actually save advanced passes to be shared and imported by somebody else?
That's the idea.
Maybe that would make more sense for advanced passes than library collections, I'm not sure.
I had the thought and figured I would throw the idea around.
