Just set up Channels on 3 Fire TVs. Everything seems to work well but do have a few issues/questions:
- Scrolling through the navigation pane - when you jump onto ‘Search’ it jumps focus to the search field which requires hitting back button to go back to the nav pane. Slightly annoying.
- ‘Fast scroll’ when in guide view. Pressing/holding down allows you to scroll through guide/channels quickly. When pressing/holding up it will jump around 10 channels but then focus on the drop down filter (All, Fav, HD etc…) Which then means pressing the button to right and up again. Any way of changing this behaviour or is there a different button press to jump up the guide?
- Surround sound turned off on all three units but Fire 4K (Pendant) unit seems to have a slight crackle in audio once in a while whilst Fire Sticks don’t seem to have this issue. All running 2.0.4. Sent through diagnostics yesterday.
Think that covers everything! Thank you for your hard work.
