Thanks @imx for the support I couldn't agree more.
@racameron I get where you are coming from; yes Amazon's fixed firmware; which fixed issues by the way, has had the knock on effect of causing this problem with Channels.
If you read above through the thread, you will see this has already been raised with Amazon, however they point at Channels as the problem. And it is Channels that has the problem. All other video playing apps, VLC included, worked both before and since the firmware change by Amazon.
This is a problem with the Channels software; a bug. VLC can play it; Channels should be able to.
Whilst typing this I finally see a response from a developer, thanks @tmm1 but 23 days with no reply is completely unacceptable for me as a paying customer. Your response also does not give me any hope of a fix.
VLC can play it without issue, and that is Open Source. Surely you can take the Open Source Code and get this fixed? It's not a bug with Amazon Firmware, its a bug in Channels.
Disney+, Apple TV, Amazon Prime Video, Netflix, Plex, Youtube, BBC iplayer, All 4, ITV player and no doubt many more, they all play all sorts of video formats without issue.
VLC and HDHomerun play the very same streams that Channels should be able to, without issue.
There is no doubt whatsoever that this is an issue with Channels.
So, @tmm1 please let me, the paying customer, know:
Can this be fixed
And if so, when?
If I had a viable alternate I would be using it right now, in fact the long lack of reply has forced me to re-set up Plex DVR earlier today. Time will tell if that's improved from its buggy mess when I tried it a year or so ago. If it's reliable, then that might make me switch away from Channels. But I don't want to. I love Channels. It's simplicity. Rock solid reliability. It never misses a recording. It's user friendly. It's powerful. It automatically doesn't record programs you have seen already. Regular updates. These and probably more make it a killer app. But not if I can't play stuff on it! So please, lets get this fixed @tmm1. Pull other developers in if needed. Speak with HDHomerun, speak with VLC. The answers are out there. I eagerly await a more positive response than the one above.
