Is anyone else experiencing issues viewing Channel recordings on an android platform, FireTV, Google made from an HDHomeRun ATSC 3.0?
My setup: I have the FireTV and Google pendant plugged into the HDMI Yamaha amp. No sound issues using Netflix, Apple, Hulu, You Tube, or Prime, but when playing a Channels recording (ABC News HD from HDHomeRun ATSC 3.0 unit, SE Michigan). The best scenario is that after selecting the recording and then ‘Watch’ the picture starts immediately but the sound takes about 5 seconds to begin. Most of the time no sound is played. I assume Channels is either not detecting or not sending the correct sound decoder details to the Amp. The recording will play correctly if you exit the Channels app go to the FireTV or Google device settings, and clear/delete all App data/cache then return to Channels. So far this action enables the sound to play on the Amp 100% of the time. Note, after limited testing I’ve also discovered if you turn off the surround sound option in the Channels playback settings, or play the sound through the TV, not the Amp, the sound also plays correctly.
