Lesson #1:
After uploading m3u, ensure to toggle the Update Sample m3u's to No. But the good news was that it's real easy to re-upload m3u's. Perhaps a future update will pop up a warning after the m3u is updated or changes the value to No.
Guide Issues:
This is probably due to me also having an Osprey ah4c source in Channels.
The guide populates fine on the webui. On clients, the choice is to stack duplicates by either Channel number or guide data. If you select Channel number all show up and channels guide shows all options and you get additional (repetitive) channels showing in the guide. If you stack by guide data, none of the channels in the new source show up because they are duplicates of existing channels of a higher priority.
My quick idea was to just create a new collection to test. After adding the new encoder channels to the collection, they show as correct then switch to the higher priority source channels.
This is not really a concern since I'll add another stick and move to test the FC ah4c bridge. @bnhf Should I expect a similar experience with FC.
@mackid1993 Your redesign and simplicity is superb. This will make life easy for those who don't understand how to use environmental variables but like webui's.
ditto also for those who do, but still like webui's
