Now, you can just upload the scripts to your local storage in browser. You can do it inside of AH4C without having to go and deal with any command line or SFTP or anything like that. So also if you pull my tag that I mentioned above, it has a full M3U editor with the ability to change channel numbers, sort, etc. Really need that stress test before @bnhf merges it into everything so.
I actually just now made a slight update to some wording, very minor, but should make it easier to understand. If you find that you need to make modifications, it should make it a little bit nicer. I also absolutely need your feedback on the Apple TV pairing. If you would also like to play with the M3U editor, I would love for someone to try to break it.
, it'd be great if you could take a look at this -- as I'm sure it'll come-up as an issue in the future otherwise.
