I have a Mohu Curve 50 Indoor "amplified" antenna.
I think the usb powered amp that comes with it is 15db.
I am looking for a lower gain or adjustable gain amp, as I think fixed db of the included usb powered amp is too much for some channels and they break up even though the HDHR stats are high, near or stay at 100%. But i have some channels that do benefit from an amp just a bit.
Are there any such low gain/adjustable gain amps out there?
I have searched on Amazon, and only thing i found was this but the reviews (sort for just the amp) are bad...and i did give it a try, and it is crap.
I need something that is like 2 to 10db (max).
Not sure if i need a LTE filter or not.
The nearest cell tower is about a half a mile or so away...i think.
The amp that comes with the antenna says it filters out such things, but since I am no longer using it, the antenna is now "passive" and direct connected to the HDHR.
