APITuner — ADB-free virtual tuner for Android TV / Google TV
Quick clarification for anyone who tried the FastChannels beta: I buried a setup requirement in the release notes. This beta requires a patched FastChannels server. Installing the updated APITuner Agent and the official FastChannels Player APK is only the TV side of the setup.
If you got stuck on the FastChannels Player Devices screen, you can skip it for APITuner. That screen is for FastChannels’ built-in ADB bridge. APITuner launches the Player through its own Agent and uses the HDMI encoder you’ve configured in APITuner.
The token is a shared secret you create yourself. Stock FastChannels doesn’t issue one. If you want to try the patched beta, I’ve updated the release notes with the full setup. If you’re running stock FastChannels, I’d hold off on this beta.
I’ve also opened a proposal with the FastChannels maintainer. The goal is for APITuner to connect to a regular FastChannels install and import channels without a server patch or ADB setup. Thanks for trying it and pointing out where you got stuck.r
i'd recommend not doing hacks to Fastchannels with this patch. we'll work something out together! happy to support more projects and a proper API connection is the right way long-term
Appreciate the coordination between you two!.
Looking forward to using FastChannels with APITuner.
Let me know if you need any beta testers. More than happy to lend a hand.
