Using this version causes severe audio problems on TVE channels. In some cases the audio runs fast in others there is only occasional blips of audio. Reverting to 2022.11.15.1908 corrects the issue.
The behavior is the same regardless of the client audio driver. And, HDHR sources are unaffected by the issue.
Server is on a Synology DS920+ running DSM 7.x. Affects all IOS and TVOS clients.
