Hello,
I have been having an issue with the audio cutting out on IFC
All other channels are fine so I am assuming it is the stream and not the server
I have submitted diagnostics
Thanks
Hello,
Thanks
If it’s just that channel you’ll likely want to find their website and report the issue to them directly. Channels won’t be able to do anything to fix the issue.
This seems to happen randomly:
The same issue is present if you watch via the IFC app.
