Audio Stutter
Hi folks:
I'm randomly hearing audio popping. It's most noticeable during live events. (Baseball / football).
Can someone help me troubleshoot? I turned off tuner sharing. I'm not seeing anything obvious in statistics, and the signal quality is 100%.
Apple TV with HDHomerun (Server running on Unraid).
Thanks.
Please run a speed test between your Apple TV and the server
What should I use to test?
But with tuner sharing turned off on your Apple TV Channels app, the connection goes from your HDHR tuner directly to your Apple TV (bypassing the server). Unless you're using Stream.
Showing 5.1ms latency, 347.7 Mbps down and 7.5 Mbps up.
