When I try going into the settings>playback>commercial Skipping option - it won't allow me to change from "Skip Button" to any other option. I can't set it to "Automatically"
It seems stuck on "Skip Button" option
Maybe someone set that setting at the server ?
I don't even see a com skip option anywhere on my server page other than enabling com detection...which is turned on.
If you are on a prerelease there is a clients Option at the top of the webpage.
Beta - Server Side Client Settings - Channels DVR - Channels Community (getchannels.com)
Ah! Found it! Thanks so much! That did the trick.
