Beta: tvOS/iOS Richer views for Library Movies and Shows
As of the latest pre-release, you can edit backdrops and logos from the web admin.
Sorry, we left this out when we shipped it out!
Additionally, you can set whether to use the rich views or not via Server Side Settings, this setting has been in the client the whole time, but we never mentioned it.
Just a usability thing I noticed for the new server side view. It isn't apparent that when I put my mouse over an image that the edit button will pop up in the corner. I was looking for something like "Edit Artwork" in the "Manage" drop down. Just don't want folks to miss this feature because it is really helpful with the new tvOS banner images.
This is fixed now in the latest build.
As of the latest TestFlight pre-release, TV series now use the new rich view on iOS and iPad OS. additionally, movies without rich art now use the new view as well on iOS and iPadOS rather than the simple modal.
I was playing around with backdrops for a show and found one that I liked better than the default. However, it has a logo on it already and then the show logo got added as well.
I would hope there’s an option to remove the logo? Maybe in the manage logos page there can be one that just says “none” or something like that which tells Channels to remove any logo for the show?
Just delete the logo image. You can do that from the web admin, that option is not available in the client.
But when there’s no logo, the title of the show is shown.
Since, i believe, app version beta 8.2.503, when i trash the last video in my video group, in my Personal Section, the app crashes to the Apple TV home screen.
I updated to app version 8.2.2016 and still experience the same issue.
I submitted diags from the app after i deleted the video, the app crashed, and i re-opened the app.
Here is a pic of how i have that section in Personal section setup, if that helps.
(it also does it on my dedicated Personal Section tab that only has this video group.)
Great, thanks, we'll look into it soon.
This has been resolved in the latest TestFlight beta:
The latest TestFlight beta adds new re-designed modals for episodes from your library that utilize the new richer art:
tvOS
iPad
iPhone
Nice! Looking slick!
Would also like to see this new UI look for normal DVR program episode/recordings too, not just local library files.
One annoyance for me, though is in my custom video groups that just have random video files I watch them delete, it’s showing the image that I set for the group, not the thumbnail the actual video when I click to show the preview of the video.
Is there any way to set that so that when I open the Video episode file preview, it shows the video thumbnail?
Video thumbnails are coming.
The eposode tags are smooshed a little bit
Others look fine though. Maybe when there are more than a certain amount of them?
Thanks, could you give me what the full list of tags is on that episode?
As of the latest TestFlight beta, video thumbnails are now utilized in the new modals.
The latest TestFlight beta handles tags a bit better to ensure they don't over flow. The build following up behind it does even more.
The latest TestFlight beta has support for launching and playing things from the Channels API and Siri Shortcuts with the new views and navigation.
Please try all your tricks to see you run into anything. If you do, please report the issues here along with a way to reproduce it.
Thanks!!
Noticing that Movie synopses are truncated in tvOS but are full text in iOS for the same movie title.
Is that intentional? Is there a way to expand tvOS text?
I hope this hasn't been asked or noted and I missed it, but I am wondering what is the size used for the backdrops?
