When i play back 1080i 50hz content Recorded by the dvr here in the UK in original mode (i.e not transcoded) my tv does not switch resolution / refresh rate and tells me it is playing content in 1080p 60 instead of 1080i 50
Channels settings:
Frame rate matching - when playing video
Decoder: hardware
Strech to fit:on
FireTV: automatic (for all display options)
The net effect is that while 1080i hd content no longer crashes the fire tv, it has so many artefacts and interlacing issues with fast moving content (jagged lines and stripes etc) its is basically unwatchable now..
Whats worse is that if i drop back from original to transcoded 720p instead (which used to work and look great) it now does nothing and just black screens then says playback failed
And worse even than that.. i now no longer have the option to use the old transcoder which also worked...
So i now have a totally broken experience and no options to fix
Please help / sort the firetv app and transcoder for UK hd 1080i content asap
