Suspected bug in 4.0.0 Search page. Right-side panel labeled New Shows & Seasons at top. Looks good on first entering search page but... When navigating down from top and reaching third row of graphics, text and graphics begin to get garbled. Text headings like "Recommended Shows" and "Upcoming Movies" get overlaid with graphic images with the result being scrambled and unusable/unreadable text and images. I hope this description of problem makes sense.
Is this with the keyboard layout where it's on the left side of the screen, vs across the top of the screen full width?
Yes. I just checked and I have one ATV4K with the left/right arrangement and one with the over and under arrangement. Left/right is the only one that exhibits the problem. Is there a setting I can change to correct this?
No it does it based on the kind of remote you use.
If you are using Bluetooth like the Siri remote, it will use the full width keyboard layout. I’d you use ir it uses the grid keyboard on the left.
I’ve been using a variety of remotes the past few days beta testing the new BT and CEC functionality. I guess that explains why I hadn’t noticed it before and why I seemed to get inconsistent screens. Anyway the left/right layout seems to have a format bug.
Everything is fine after I deleted the app and re-loaded it from the apple store. Thanks for the help everyone!
The problem seems to have been caused by me looking for the the "sidebar-settings" that were not there: menu-button works as it should after rebooting the whole atv.
(i.e somehow by going over all the settings-menus multiple times I caused the menu-button bug, but I don't know how)
Have you been successful in activating it?
When I try it every other time the "logo animates" and nothing happens and every other time "logo animates" and I am booted to the settings menu. But the settings menu is still there, strange
I'm curious why the decision was made to bury The "scheduled recordings" menu under the settings menu. I use this option on a daily basis, and now it's a real pain to get to. I've looked through ways to configure the sidebar menu, and see nothing to allow this to be fixed. It's not like the "Scheduled Recordings" menu is a set once and forget menu option, there's all kinds of reasons to jump into this menu often. Please consider putting it back where it's easy to access. I can deal with the rest of the changes in 4.x, but this one is a sticking point as it makes the interface harder to use.
Agreed. I frequently use this page to manage upcoming recordings, skip some recordings, or adjust some pass priorities. (The Passes and Trash can justifiably be under the Settings banner, as they are far less frequently used.)
I do not like it being buried either I frequently use it.
Based on this other thread, it looks like the Channels Developers have added the ability to turn on the navigation shortcut in the latest beta build.
I hope that this is exactly what he was talking about over in the other thread, and hope that it comes to the release channel soon. It just never made much sense at all to bury an item that so many use on a daily basis. Would of loved to been able to give that input about this and other things during beta, but I was too sick to participate for quite some time, so hopefully it's not too late to fix some of this stuff like this.
It was discussed in the Beta testing. I brought it up as well as several other testers. The developers chose not to address our concerns.
As mentioned, the option to add Schedule to the sidebar has been added. The update is in review right now and should be available later today or tomorrow.
You can get it right away if you join the beta program and get the version on testflight.
Channels v4.0.3 is now available for update via the App Store.
