Same here. Also crashes on TV Shows section. Only recordings from the Recordings screen don't crash.
the source of the crash is that these files changed somewhat on may 5th. reapplying the color edits to those files should take care of it.
I assume you mean you're reapplying the color edits? I'll try again when I get home from work tonight.
it's possible to prevent this in the future by modifying only the colors file, but i can't get everything changed the way i want it by only editing that, so i'll do a more rigorous QA from here. I can't expect them to not work on their app, so this will probably happen again in the future, i just need to catch it before putting new stuff up
Not a problem. Just making you aware. I appreciate the effort.
How I get that color theme?
How can i get that theme?
Installation instructions are in the first post.
105.15.2113
Not a frequent user of Google Drive, can I just bookmark the file location to download it every time you update? Currently I just scroll back to post 1 to download the update. I know with Dropbox I can essentially map your folder location to mine, not sure if a similar function applies with GD.
You could use Filelinked which uses a Dropbox link, so in the future I will provide that link also. But it changes with every new version. The Google drive link never changes so it could be bookmarked, yes.
Thanks. I'll look into it. This TV is the only Android device in the house, so not too familiar with all the ins and outs. I figured out how to use ADB from my Mac and use that to install each update.
I do that just fine.
The Google drive link never changes. You can add a link to it in your own drive.
Sob..... why..... can't..... ChannelsDVR..... support.... this.... nativley..... sob.....
So beautiful (not the purple)
105.19.1815
105.22.1920
105.25.2217
105.28.105
