Channels Carbon Theme
Awesome thx. Ill try it out tonight.
I've got X-Plore installed, shortcut added, but when I click the shortcut in X-Plore, I get an error: Copy Error: HTTP error: Only files with binary content can be downloaded. Use export with Docs Editors files. What's that mean?
I have absolutely no clue. I just tried it again and it worked for me. Maybe long press and choose 'Install' ? There's also an 'Open with". And probably a way to download it to your internal storage.
Tried long press install, same. Could it be because I just have it as a shortcut, whereas you have the actual file in your GDrive? I'll just keep with the old way of downloading the apk to my mac and using ADP for install it.
Could be. I thought the same also. Damn. Was really wanting to figure out an easier way for y'all. I mapped my shields drive and just drag it over.
II's no big deal, appreciate the effort. Don't use it much now that I got an Apple TV but can't stand watching sports where you can't see thru the timeline bar, so thanks to your hard work, we have options besides opaque purple blocking the bottom ¼ of the screen when skipping ahead or back.
I got the same error as well. Thank you for trying a new method for updating but it didn't work for me. The regular way of installing it is fine though. I use this theme exclusively on my 4 NVIDIA shields and appreciate your efforts.
Do you think you could update this theme to the next beta?
" v2021.12.09.1954
Add clock to the video player quick guide"
Having this clock would be useful
Thanks
Sure, expect an update later this afternoon.
Great thx!
112.9.1954
Thank you! Amazing how useful a clock is.
So I decided to start tracking my heart rate at work (gf bought me a fancy watch)...
FML....
My Apple Watch happily tells me I have poor “Cardiac Fitness”. Tell me something I don’t know… lol
112.22.237
Thank you
Thanks again for you work
This is on hold unfortunately until I can figure out why it doesn't recompile correctly anymore. I noticed a lot of new files / folders in the /res folder that wasn't present before which prompted me to ask @tmm1 if anything had changed. He said that the Android Studio version had been upgraded, and suggested that I see if my tools have updates available. I am using APK Easy Tools 1.59.2 (current), decompile / recompile using apktool.jar 2.5, but there was an update to 2.6. Switched it over to the newer version and still get recompile errors without actually changing anything (replacing the files to change the colors). So with anything I can't figure out, I tried the destroy it and rebuild method (format my computer and install windows / programs fresh). Still recompile errors. All I can come up with is APK Easy Tools needs to be updated. I have reached out to the developers of that for insight. I apologize for the inconvenience.
