I had the same problem but I don't know that it has anything to do with the carbon theme.
Updated to latest beta (not carbon
) fixed the issue.
I'll make another update and see if it still does it. If it does, investigate. Thanks for reporting it.
Updated to 11.7.1925
Crash source found and fixed. At some point code changed in a few files I made edits to and I didn't notice, so that's on me.
Thanks. Working as expected.
Thanks you working now.
Sorry @AtoZ0to9 I take that back, using filesynced I installed the new version but I am getting the same issue when I go to play a recorded tv show.
I believe you need to go into the downloads in filesynced and hit the 'clear downloads' and redownload it again, it's working for me.
After it's installed, verify it's the new version in settings > support > about
Thank you as that was the issue. Sorry it's my first time using the filesynced setup. Thank you.
No, thank you.
How can I get this on my Fire Cube in my bedroom, love it on my shield- not sure how to get the file to the cube
This is something I wish the oems would make easier, just copying a file to the box. A few ways come to mind. Install puffin tv browser from the play store and navigate to the filesynced website and click the link to download it's .APK. use filesynced. Or install X-Plore file manager from the play store and use it's wifi server file transfer feature, to send it from a different device. Or I remember an app called Apps2Fire, on the play store, of course, where you could install the app to fire devices from your android phone.
I guess I'm spoiled. I have a Win10 Box on the same network and simply FTP files to my mobile Android devices.
On my Shield they make it even easier with Settings >> Device Prefs >> Storage >> Transfer Files Over Local Network turned on.
On my handheld Androids I've been using FTP Server pro for 10 years at least. Simply run it and connect from my Windows box, then shut the server on the device off when done sending files.
Too lazy to search this thread to see how many times I've mentioned this before, but it is convenient as heck assuming you have a desktop box on your LAN.
AndFTP, and AndSMB are great apps for simple file transfers too.
Perfect thanks
Thanks for keeping this going! 11.7.1929 running on ShieldTV just fine.
12.1.2119
Can we get an updated version when you get the chance.
Sure, have it up later today.
12.17.2204
Before I try and install, what happens when an updated version is needed? WAF is important and if something "breaks" or requires having to do something different during the period awaiting updates, I'd rather not pursue.
Thanks,
Jay
