If you sideload it should install as a separate instance with it's own settings etc. It works like this on Android TV, now you have me curious if it will work the same on my tablet(s).
If this colorized beta version breaks, switch over to the stable version.
[Off to test on my tablet] [edit] <--- yes, sideloads as a 2nd instance when I transferred manually to tablet and installed, unsure how it installs from the utility mentioned at the top of the thread.
Thank you.
