Channels Carbon Theme
What files are modified here? If we wanted to recompile this ourselves with the latest apk, which files are we replacing? Is it more than just colors.xml?
I haven't had the opportunity to create the app I was talking about earlier but following AtoZ0to9's instructions from the top of the thread I was able to create a blue theme using ChatGPT (free version). I zipped up the entire Res folder from the decompiled APK of the latest beta, uploaded to ChatGPT and instructed it to change all purple colors to corresponding shades of blue. I also instructed it not to alter any fonts or any other colors. It took about 5 minutes. I download the file, unzipped it and copied the whole thing back into the original apk, overwriting the old files. On my nVidia Shield I had to uninstall the Channels app and then it installed fine. Looks great and seems to be working great. Not bad for a first try. Will experiment more when I have the chance.
Would you be able to share this file?
That's totally awesome. I've been doing some vibecoding with Claude for some niche use cases and pet projects I'd been thinking about for awhile and am having pretty surprising success. Given how arduous of a process AtoZ0to9 described this to be, I had the thought that AI could help with this project specifically, and now I'm glad to see that's true!
Looking forward to seeing developments in this space moving forward.
Absolutely, but I've never shared a file before. I have a free Dropbox acct, would that be good for this? Or is there another site that would be better for this? As long as it's free.
Yeah, I've been watching some YT vids on vibe coding. Very interesting stuff going on.
Dropbox should work fine.
Ok, let's see if this link works.
https://www.dropbox.com/scl/fi/jsguel6za2fuwg80hd4bi/_channels-dvr-710090549-blue.apk?rlkey=4clizfbagyd1tv8fnpjy3vo5b&st=tx7gs79m&dl=0
Doing some experimenting with just the channel grid now. This is the first version, I'll continue to work on it and then other sections.
It worked! Thank you. My TV's File Manager app did flag the file as harmful, however. I had to temporarily turn off Play Protect. I also had to uninstall Channels Carbon first. But it looks good.
Let me add that the inability to have themes by default is pretty outrageous for an app we pay for monthly. I've been a paying customer for nearly 8 years. I've found a couple pretty solid alternatives, each with their limitations. One simply being an SMB network issue with my Mac for use with their DVR player, which I've been trying to solve. I'll also add that each of their GUIs are miles ahead of Channels, which is a pretty huge factor that Channels developer's clearly don't give serious consideration.
That said, I look forward to how AI and one's imagination may improve this situation for now, but it's a shame it's had to come to this.
I'm glad you like it. However - and I'm very new to this so maybe someone else can clarify it - if you turn Play Protect back on it may block the app sooner or later. This has something to do with a "key" or "signature key", I forget what it's called. Due to changes Android made in its policy a while back I think apps are supposed to be "officially" signed, a lot of folks were raising hell that they couldn't sideload apps anymore. I had problems with sideloaded apps so I turned off Play Protect and have left it that way. As I understand it, when I recompiled the apk after modifying it, the APK Editor Studio app I'm using assigned an "unofficial" key. But without that I don't think the app will install at all, with or without Play Protect.
Again, this is far from my area of expertise but I believe that's the gist of it. If someone reading this knows of a solution to this issue perhaps they'll let us know.
EDIT: BTW, this issue didn't occur to me until you mentioned it which is why I didn't bring it up. As I say, I'm very new to this.
So I just enabled Play Protect and rebooted my system. I figure if there is any point at which it will block any apps it will be after a reboot. The Channels app opened fine and is working fine. This is on my nVidia Shield. It may behave differently on your device, I don't know.
The first theme I created, which just replaced all purple colors with blue, I'm calling the Flat Blue theme. This current theme, with the 3D-ish effects, I'm calling the Neon Blue theme. Here is a pic of Neon Blue version 2.
EDIT: Since this may be an ongoing project and I don't want to usurp this thread I've started my own, titled "Neon Blue Theme for Android". Download links to the Flat Blue and Neon Blue themes are there.
