I've created a couple of themes in the latest beta using ChatGPT (free version). Thanks to AtoZ0to9 in the Channels Carbon Theme thread for his instructions on decompiling APK's and info on the Channels DVR folder to edit ("res" folder). The first theme I call Flat Blue and simply replaces all shades of purple with corresponding shades of blue. The second theme, Neon Blue, is a variation that gives the channel grid a more polished (I hope) 3D-ish look. Except for the channel grid, all other sections in both themes are the same. Screenshots and links below.
To install you'll probably need to first uninstall your current Channels DVR app and turn off Play Protect. If you turn Play Protect back on after installation I can't say whether or not Android will block the app at some point, that's above my paygrade. For what it's worth, on my nVidia Shield I enabled Play Protect and rebooted, assuming if it was going to block an app it would probably be after a reboot. The app opened and worked fine. Your mileage may vary.
If the download links don't work lemme know, they're from my free Dropbox account.
I may do other versions and colors in the future.
Flat Blue:
Neon Blue:
Neon Teal
