Thank you for clearing that up.
Hi there - Iāve been using the channels app on my Apple TV for quite some time and love the experience. I may be getting a new TCL tv later this year that has built in Roku, so am wondering how robust the Roku app is. It sounds like itās experimental - any anecdotes on its performance given it needs to transcode (eg how long does it take to tune a channel, seek, etc)? And any thoughts on making the app perform better over time (eg Iāve been following the fire tv thread and sounds like thereās progress in avoiding transcoding, etc)? Appreciate the help as Iād love to stay with channels but see if I can ditch my Apple TV in favor of Roku
Hi - thought Iād nudge this. Any thoughts/update on the Roku side of things when you get a moment (congrats btw on the great progress w/ Fire TV⦠just wanted to check on the Roku side which also has significant user base).
We have our hands quite full with Android/FireTV, and Roku is not really a priority at the moment. The fact that the majority of Roku devices cannot decode mpeg2 combined with the fact that the Roku SDK is quite limited and not very fun to work with makes it hard to get excited about that platform.
k thanks⦠appreciate the visibility and update. Iāll hang on to my apple tvs for the time being
IMO, would rather see progress on Android TV/Fire TV than Roku, although have all three devices.
I've been having issues lately with the app.
the app opens fine and the channels preview thumbnails load up as well. When i click a channel to load. I keep getting the following error ...
Video Player Error : ignored
can someone help? i cant seem to figure out the problem
Can you play stuff on the web player? Are there errors on the DVR log tab?
I get the same message when using the Roku app. Mainly use firestick but wanted to try Roku app.
it plays fine on the web player but from the roku this have been a constant issue. I can't figure it out.
here the log error
018/11/04 21:18:25 [ERR] Failed to start stream for ch505: Get http://ipaddress:5004/auto/v505?: dial tcp ipaddress:5004: connect: no route to host
this error happens when it's live tv, but for anything i recorded it works fine.
That means the DVR cannot connect to your hdhomerun. Is the IP correct?
the ip address matches the HDHome run. I not sure what the port suppose to be. I really don't understand how ports work with router and devices
So Roku can play recordings but on live tv it errors?
And web player can play both recordings and live tv?
Based on that error I would expect that all live tv (from web player or Roku) would fail. And new recordings would fail too, because it can't connect.
Port 5004 is what hdhomerun uses for video data.
i checked again and the ip address is different. The hdhome run has a new ip address and the channels DVR is looking for the old ip address it was on
is there a way i can make it look at the new HDHome run Ip address?
In the section where the hdhomeruns are shown, click the gear dropdown and select Scan Network.
I would recommend you add a static dhcp reservation to your router for your DVR and HDHR so the IPs don't change.
Do you know where i can find instructions on how to do that? i have a fios quantum gateway router?
btw thank you for help and quick response
Is this app still being worked on? Is there a way to connect it remotely to the Channels server? Right now it just says there's no DVR found on my home network (which is remote from the server), and when I scroll down to "Up Next" the app crashes.
No the Roku app is only a prototype and not under active development. It does not support remote access.
Just fired it up on my Roku Ultra (4660) and it's working for Live TV (both MPEG-2 and PTV H254) and recorded OTA (MPEG-2). Recorded HD-PTV (H264) fails on load with an error I can't read (off the screen at the bottom). I have Hardware 'disabled'. Did not use the 'Play on Roku' feature. Just fired it up from the page provided.
The Roku Ultra and most of the "New" Rokus do support MPEG-2 - might be noteworthy albeit inconvenient due to the sheer number of legacy Roku devices out there.
I came to see if Channels was supporting Roku now that they have MPEG2 support-- as far as older devices go I think apps can be excluded based on model and Channels would just need to advertise appropriately as "2015 models or newer", something like that anyway.
