Is there anyway I can auto import a list from m3u8 to channels without manually having to do it?
You’d have to describe what you want with a bit more detail.
I have a m3u8 that the link changes at times. I manually add them was just wondering if there was a path I can auto move to change the links in the source.
Channels DVR Server auto refreshes m3u URLs to update the channels at an optional rate.
So if the channel URLs change, they will get updated. You have to use an m3u url for this to work, snd not the text option.
Can you help me take a m3u8 file (from DwellingsTV) and get the stations in ChannelsDVR?
