So I've been having issues where I'm using just any device like a Apple TV or a Nvidia Shield TV And Channels just sits there saying "preparing your TV" and does nothing..
I'm just waiting and it surpasses 2+ mins and I just end up quitting the app and go to my Plex app where it loads and I'm in watching TV under 30 seconds(22 seconds to be exact).
This is with my full library of TV shows and movies and recordings.
I have it on my computer that's band new i7-13700k and 32GB of memory hardwared to my network.
And channels is up to date on a beta.
Both are on a fast SSD, channels is saying 4GBps write and 10 GBps read.
I used to have channels pointing to a Stablebit drive pool so I thought it was that so I moved channels to the SSD with same issue
I use the computer both for gaming and TV..well most of the time each task at once but when I'm gaming Plex doesn't have any issue doing both recording/watching TV on a different device if my family so chooses.
Please any help. Thanks
Oh and I've done a complete reinstall of channels thinking it was that with the same issue.
) when I could and I thought of just doing a fresh install since I tried everything else even doing away with the hardware firewall and the fresh install seems to have helped a lot!
