Channels will not load ATV
Same problem here, couldn’t update so I deleted and now can’t install stuck at 2/3. Very annoying, specially being a pay user.
I can’t load it on my ATV either. Ended up deleting it so I could reinstall and now I’m in the same boat as others. The app isn’t searchable in the App Store for ATV. I had to go to my purchases, but even there, the icon is black. Can you please send me the beta? Thanks.
got the email and click on it then nothing happens
Can you please resend the email? I posted after you had already sent it the first time. Thanks.
States it for apple tv not windows!
Just got it. Thanks!
Click on the link in the email to get a code, then type that into TestFlight app on your Apple TV.
Yes I get the link on a windows computer. Unfortunately it is for MAC!
The link works on any computer, phone or tablet. It has nothing to do with a mac.
so tell me how to load on a ATV?
Aman and Gregory_Board
Actually, the link works with Chrome on Windows but the new Edge browser tries to offer you a menu to choose an app to open the link with and if you choose IE you get a blank page. On Windows it looks like the Chrome browser is your best bet.
Same issue. Would like a TestFlight code as well. Thanks
You take the code provided from the link in the email and enter it into the Test Flight App on your Apple TV. On Windows, Chrome works when you click the link to display the code, Edge seems to want to find an App to open the link.
Can I have the beta please. My app is currently unusable. Thanks.
[email protected]
Apple is now aware of the bug and is looking into the root cause.
Interestingly… if you have tvOS 10.2 Beta installed on your ATV then the new app installs just fine from the App Store.
I have no app on any of my Apple TV
I guess I’m Going to be without tv this weekend as Apple Store doesn’t make store changes during the weekend?
You can use the beta app in the mean time. Check your email/spam folder for the invite.
App Store updates do happen on the weekend, and we hope Apple will be able to fix this issue soon as they are aware of the problem and working on it.
Also see the same issue downloading CHANNELS app. Can I also have a copy of the beta app?
I am having the same issues also. Can I also get the testflight beta.
