What buffer is low?
I was watching a minute behind live and it stopped, showed buffering at 4:27 even though it had buffered to 5:27.
10:16:20.990 event
Object { Type: "activities.set", Name: "7-ch735-dANY-ip192.168.1.2", Value: "Watching ch735 from 192.168.1.2 (Remux Running at 2mbps: 5m26s @ 1.00x (59.94fps)): strength=97% quality=100% symbol=100% rate=1.9Mb/sec" }
bundle.js:32:4684972
10:16:21.028 [debug] > call to loadLevel bundle.js:62:30745
10:16:21.029 [log] > Attempt loading level index 0 with URL-id 0 bundle.js:62:30745
10:16:21.029 [debug] > Loading playlist of type level, level: 0, id: 0 bundle.js:62:30745
10:16:21.029 [debug] > Calling internal loader delegate for URL: http://192.168.1.4:8089/devices/ANY/channels/735/hls/stream.m3u8?abitrate=128&abr=false&acodec=aac&bitrate=2779&deinterlacer=hardware&indexed=true&resolution=720&ssize=1&vcodec=copy bundle.js:62:30745
10:16:21.628 [log] > same live playlist, reload twice faster bundle.js:62:30745
10:16:21.629 [log] > live playlist, reload in 496 ms bundle.js:62:30745
10:16:21.629 [log] > level 0 loaded [1,328],duration:325.3167140000005 bundle.js:62:30745
10:16:21.629 [log] > live playlist sliding:0.000 bundle.js:62:30745
10:16:21.879 [warn] > Playback stalling at @267.754677 due to low buffer bundle.js:62:30745
I skipped back 10 secs and it played to 4:27 again and stopped, showing buffering.
10:17:23.469 [log] > media seeking to 257.755 bundle.js:62:30745
10:17:23.495 [log] > same live playlist, reload twice faster bundle.js:62:30745
10:17:23.495 [log] > live playlist, reload in 514 ms bundle.js:62:30745
10:17:23.496 [log] > level 0 loaded [1,377],duration:387.3246890000003 bundle.js:62:30745
10:17:23.496 [log] > live playlist sliding:0.000 bundle.js:62:30745
10:17:23.865 [log] > media seeked to 257.755 bundle.js:62:30745
10:17:34.481 [log] > level 0 loaded [1,385],duration:399.3326890000003 bundle.js:62:30745
10:17:34.482 [log] > live playlist sliding:0.000 bundle.js:62:30745
10:17:35.151 [warn] > Playback stalling at @267.754677 due to low buffer bundle.js:62:30745
I also noticed that this sequence of main stream:IDLE->FRAG_LOADING->PARSING->PARSED->IDLE stopped here at 267 seconds, where the buffering appears in playback.
10:15:19.992 [log] > Loading 266 of [1 ,268],level 0, currentTime:207.073,bufferEnd:264.960 bundle.js:62:30745
10:15:19.994 [log] > main stream:IDLE->FRAG_LOADING bundle.js:62:30745
10:15:20.634 [log] > Loaded 266 of [1 ,268],level 0 bundle.js:62:30745
10:15:20.635 [log] > Parsing 266 of [1 ,268],level 0, cc 0 bundle.js:62:30745
10:15:20.635 [log] > main stream:FRAG_LOADING->PARSING bundle.js:62:30745
10:15:20.650 [warn] > Injecting 1 audio frame @ 266.283s due to 31 ms gap. 2bdb07f5-7dfa-4329-ada8-4ea723318c06:1:6202
10:15:20.651 [log] > Parsed audio,PTS:[264.960,267.755],DTS:[264.960/267.755],nb:131,dropped:0 bundle.js:62:30745
10:15:20.653 [log] > Parsed video,PTS:[265.052,267.847],DTS:[264.952/267.763],nb:150,dropped:0 bundle.js:62:30745
10:15:20.655 [log] > main stream:PARSING->PARSED bundle.js:62:30745
10:15:20.663 [log] > main buffered : [12.650,106.744][106.777,267.755] bundle.js:62:30745
10:15:20.664 [log] > main stream:PARSED->IDLE bundle.js:62:30745
10:15:20.677 event
Object { Type: "activities.set", Name: "7-ch735-dANY-ip192.168.1.2", Value: "Watching ch735 from 192.168.1.2 (Remux Running at 2mbps: 4m28s @ 1.01x (59.82fps)): strength=97% quality=100% symbol=100% rate=3.9Mb/sec" }
I can email you this console output if you want.
