Interestingly, I was testing with WeatherStar 4000+, and that was working fine. Now testing with a Sling channel, I'm seeing one failure followed by an immediate success:
Google Chrome 140.0.7339.127
The VNC desktop is: d21dc53fb3f5:0
The VNC port is: 5900
[2025/09/10 12:31:43.567] Selected settings:
[2025/09/10 12:31:43.569] Video Bitrate: 9500000 bps (9.5Mbps)
[2025/09/10 12:31:43.569] Audio Bitrate: 256000 bps (256kbps)
[2025/09/10 12:31:43.569] Minimum Frame Rate: 60 fps
[2025/09/10 12:31:43.569] Port: 5589
[2025/09/10 12:31:43.569] Resolution: 1920x1080
[2025/09/10 12:31:43.574] Chrome Capture server listening on port 5589
[2025/09/10 12:32:13.128] Launching Browser, Opts {
executablePath: '/usr/bin/google-chrome',
pipe: true,
headless: false,
defaultViewport: null,
userDataDir: '/home/chrome/chromedata',
'--no-first-run',
'--hide-crash-restore-bubble',
'--allow-running-insecure-content',
'--autoplay-policy=no-user-gesture-required',
'--disable-blink-features=AutomationControlled',
'--hide-scrollbars',
'--window-size=1920,1080',
'--disable-notifications',
'--disable-background-networking',
'--disable-background-timer-throttling',
'--disable-background-media-suspend',
'--disable-backgrounding-occluded-windows',
'--auto-accept-this-tab-capture',
'--allowlisted-extension-id=jjndjgheafjngoipoacpjgeicjeomjli',
'--use-gl=angle',
'--use-angle=gl-egl',
'--enable-features=VaapiVideoDecoder,VaapiVideoEncoder',
'--ignore-gpu-blocklist',
'--enable-zero-copy',
'--enable-drdc',
'--no-sandbox'
ignoreDefaultArgs: [
'--enable-automation',
'--disable-extensions',
'--disable-default-apps',
'--disable-component-update',
'--disable-component-extensions-with-background-pages',
'--enable-blink-features=IdleDetection',
'--mute-audio'
enableExtensions: [ '/home/chrome/node_modules/puppeteer-stream/extension' ]
179 | ensureNewDocumentNavigation = !!response.loaderId;
180 | if (response.errorText === 'net::ERR_HTTP_RESPONSE_CODE_FAILURE') {
181 | return null;
182 | }
183 | return response.errorText
184 | ? new Error(`${response.errorText} at ${url}`)
error: net::ERR_BLOCKED_BY_CLIENT at chrome-extension://jjndjgheafjngoipoacpjgeicjeomjli/options.html#55200
at navigate (/home/chrome/node_modules/puppeteer-core/lib/cjs/puppeteer/cdp/Frame.js:184:27)
[2025/09/10 12:32:13.335] New target page created: about:blank
Bun v1.2.21 (Linux x64)
Cleaning up...
[2025/09/10 12:32:15.836] Selected settings:
[2025/09/10 12:32:15.838] Video Bitrate: 9500000 bps (9.5Mbps)
[2025/09/10 12:32:15.838] Audio Bitrate: 256000 bps (256kbps)
[2025/09/10 12:32:15.838] Minimum Frame Rate: 60 fps
[2025/09/10 12:32:15.838] Port: 5589
[2025/09/10 12:32:15.838] Resolution: 1920x1080
[2025/09/10 12:32:15.844] Chrome Capture server listening on port 5589
[2025/09/10 12:32:15.959] Launching Browser, Opts {
pipe: true,
headless: false,
'--no-first-run',
'--use-gl=angle',
'--enable-drdc',
'--no-sandbox'
'--mute-audio'
[2025/09/10 12:32:16.130] New target page created: about:blank
[2025/09/10 12:32:16.139] Target page changed: chrome-extension://jjndjgheafjngoipoacpjgeicjeomjli/options.html#55200
[2025/09/10 12:32:16.155] New target page created: chrome-extension://fignfifoniblkonapihmkfakmlgkbkcf/service_worker.js
[2025/09/10 12:32:16.164] New target page created: chrome-extension://jjndjgheafjngoipoacpjgeicjeomjli/background.js
[2025/09/10 12:32:17.147] Need to initialize stream capabilities
[2025/09/10 12:32:17.330] streaming https://watch.sling.com/1/channel/1a3c345b84b149918e0bad8f797df70a/watch
[2025/09/10 12:32:17.416] Target page changed: https://watch.sling.com/1/channel/1a3c345b84b149918e0bad8f797df70a/watch
[2025/09/10 12:32:17.428] URL contains watch.sling.com
[2025/09/10 12:32:17.933] New target page created: https://watch.sling.com/7.1.8/service-worker.js
[2025/09/10 12:32:19.812] New target page created: blob:https://watch.sling.com/dab983f0-ccfc-42b3-8d71-04b17efd7663
[2025/09/10 12:32:19.852] Browser page closed: blob:https://watch.sling.com/dab983f0-ccfc-42b3-8d71-04b17efd7663
[2025/09/10 12:32:22.650] Set Sling to Full Screen and Volume to max
[2025/09/10 12:32:46.165] Browser page closed: chrome-extension://fignfifoniblkonapihmkfakmlgkbkcf/service_worker.js
[2025/09/10 12:32:46.166] Browser page closed: chrome-extension://jjndjgheafjngoipoacpjgeicjeomjli/background.js
[2025/09/10 12:32:49.342] Browser page closed: https://watch.sling.com/7.1.8/service-worker.js
EDIT: BTW, you can also try bnhf/cc4c:test if you like, which is still using Chrome 136.
