Commercial skipping is failing on TrueNAS Core with "signal: abort trap"
I submitted the DVR Diagnostic Log 0a520ba2-712c-4069-97aa-e9ba49633696 with description. For some reason I'm not hearing back.
This is a log snip:
2023/03/14 21:01:00.001504 [TNR] Closed connection to 13246959/0 for ch511 CW WPIX-DT
2023/03/14 21:01:00.005977 [SNR] Statistics for "TV/Superman & Lois/Superman & Lois S03E01 Closer 2023-03-14-2000.mpg": ss=100% snq=100% seq=100% bps=7854227,1831872-14545184 pps=672,157-1245
2023/03/14 21:01:00.011201 [SNR] Buffer statistics for "TV/Superman & Lois/Superman & Lois S03E01 Closer 2023-03-14-2000.mpg": buf=0% drop=0%
2023/03/14 21:01:00.016730 [DVR] Finished job 1678838400-144 Superman & Lois
2023/03/14 21:01:00.025596 [DVR] Processing file-2094: TV/Superman & Lois/Superman & Lois S03E01 Closer 2023-03-14-2000.mpg
2023/03/14 21:01:00.167200 [DVR] Running commercial detection on file 2094 (TV/Superman & Lois/Superman & Lois S03E01 Closer 2023-03-14-2000.mpg)
2023/03/14 21:01:01.725068 [DVR] Commercial detection failed for Superman & Lois S03E01 Closer 2023-03-14-2000.mpg with signal: abort trap
I tried to Redetect Commercials and also got the same error. Log snip:
2023/03/18 12:46:18.322873 [DVR] Running commercial detection on file 2094 (TV/Superman & Lois/Superman & Lois S03E01 Closer 2023-03-14-2000.mpg)
2023/03/18 12:46:20.077577 [DVR] Commercial detection failed for Superman & Lois S03E01 Closer 2023-03-14-2000.mpg with signal: abort trap
Thank you for your assistance,
Morris
Did you look in the comskip log?
The log file is in the folder Logs/comskip/2094
So Logs/comskip/2094/video.log
Also available via http://<dvr_ip:dvr_port>/dvr/files/2094/comskip.log
I see nothing of interest in the comskip log. It shows it started and eventually displays the logo the at the end of the log:
Logo found at frame 2697 logoMinX=827 logoMaxX=917 logoMinY=467 logoMaxY=510
******************* End of Logo Processing ***************
Any other idea?
By the way, my server is TrueNAS Core and everything is up to date. It had worked well in the past. Then it started erroring as above.
Thank you Terry,
So this is going on for over a week for you and about the time I started to see the issue. Quite a while back, I had similar issues with Plex on TrueNAS and got tired of waiting for a fix and moved Plex to a VM on TrueNAS. A month or so ago I had issues with my Channels DVR Windows VM on TrueNAS and moved to a plug-in and now this. I'm not getting the warm fuzzies with how long your thread has sat idle and mine being ignored while the developers respond quickly to others.
I don't think it is so much they are being unresponsive as it is this is a head scratcher for them.
Perhaps we just need to provide them with more information.
Commercial detection is working for me I am just unable to edit and verify any recordings. Any recordings that have already been edited and verified are working as intended when using re-edit function.
My current Version:TrueNAS-13.0-U4 ( rolled back to 13-U3.1 no change went back to U4 )
Chromium version 111.0.5563.64 in my jail. (updated to 111.0.5563.64_1 no change )
Maybe if we can find a common factor we can help the Devs figure this out.
I get that they seem stumped looking at your thread. It would have been nice to at least have them acknowledge that there is a problem that they have been investigating. To me it seems like they are spreading them selves too thin trying to support so many server solutions. I have an old I-3 Windows laptop and I have it updating right now. It's my backup plan for now.
My current Version:TrueNAS-13.0-U4 installed 2023-03-01 15:15:00
My first recording that exhibited the issue was 60 Minutes from CBS recorded on 2023-03-12. I don't record a lot via my HD Homerun. The previous 60 Minutes was not interesting to me so I did not watch it. Possibly it exhibited the issue.
I don't generate commercial editor thumbnails.
For Chromium I've got:
action=version product=HeadlessChrome/109.0.5414.119 jsVersion=10.9.194.10 protocol=1.3 [email protected]
Other interesting data:
OS
Freebsd
13.1-release-p7 (kernel: 13.1-release-p7)
CPU
16 cores / AMD Ryzen 7 5700G with Radeon Graphics
load averages: 0.13 0.26 0.27
RAM
27.84 GB
49.9% free
When did you first notice com skip detection issues?
What CPU are you using?
My detection seems to run without issue it is when trying to verify and fine tune the auto detection where mine is failing.
OS
Freebsd
CPU
4 cores / AMD FX(tm)-4100 Quad-Core Processor
( Yes it is OLD but actually works rather well )
load averages: 0.27 0.21 0.19
RAM
15.87 GB ( 16 GB in total )
82.8% free
My last verified recording was January 29 in early AM so I would not have edited it until the 30/31 at a guess. That is the last verified recording I have.
On a side note mine does not appear to be date specific as even recordings made earlier if they had not been verified are also exhibiting the same issue.
I did some research and I think we are dealing with a bad version of ffmpeg and it needs to be updated. Researching that, I discovered that ffmpeg is made up of a hole bunch of modules and libraries and updating is complicated and probably time consuming. They may need to build a TrueNAS core box to build the new ffmpeg and test it. I wonder if any of the others running TrueNAS Core are experiencing this? I just updated the subject to get there attention.
We are still investigating. It appears to be freebsd specific issue. If you can find more details about the abort in the OS or kernel logs, that would be helpful.
Thank you for the update. I don't see anything of interest from the command line of the jail. Noting is logged at the TrueNAS level. To me it looks like ffmpeg starts to process the file and then quits and must be sending the "Signal: Abort Trap" back to channels where it's logged. I conclude this looking at comskip .log
Generated using donator Comskip 0.82.011
Time at start of run:
Sat Mar 18 14:41:47 2023
Mpeg:	/media/DVR/TV/Superman & Lois/Superman & Lois S03E01 Closer 2023-03-14-2000.mpg
Exe	comskip.exe
Logo:	/media/DVR/Logs/comskip/2094/video.logo.txt
Ini:	/media/DVR/Logs/comskip/2094/comskip.ini
Detection Methods to be used:
	1) Black Frame
	2) Logo - Give up after 2000 seconds
	3) Resolution Change
	4) Closed Captions
	5) Aspect Ratio
	6) Silence
ComSkip throttles back from -0001 to -0001.
The time is now 1441 so it's full speed ahead!
Settings
[Main Settings]
;the sum of the values for which kind of frames comskip will consider as possible cutpoints: 1=uniform (black or any other color) frame, 2=logo, 4=scene change, 8=resolution change, 16=closed captions, 32=aspect ration, 64=silence, 255=all.
detect_method=123
;Set to 10 to show a lot of extra info, level 5 is also OK, set to 0 to disable
verbose=10
;Frame not black if any of the pixels of the frame has a brightness greater than this (scale 0 to 255)
max_brightness=60
maxbright=1
;Frame not pure black if a small number of the pixels of the frame has a brightness greater than this. To decide if the frame is truly black, comskip will also check average brightness (scale 0 to 255)
test_brightness=40
max_avg_brightness=19
max_commercialbreak=600
min_commercialbreak=45
max_commercial_size=120
min_commercial_size=4
min_show_segment_length=222
max_volume=500
max_silence=100
non_uniformity=500
[Detailed Settings]
min_silence=12
remove_silent_segments=0
noise_level=5
brightness_jump=200
fps=1
validate_silence=1
validate_uniform=1
validate_scenechange=1
global_threshold=1.05
disable_heuristics=0
cut_on_ac_change=1
[CPU Load Reduction]
thread_count=3
hardware_decode=0
play_nice_start=-1
play_nice_end=-1
play_nice_sleep=2
[Input Correction]
max_repair_size=40
ms_audio_delay=5
volume_slip=40
lowres=1
skip_b_frames=0
[Aspect Ratio]
ar_delta=0.08
cut_on_ar_change=1
[Global Removes]
padding=0
remove_before=0
remove_after=0
added_recording=14
delete_show_after_last_commercial=0
delete_show_before_first_commercial=0
delete_show_before_or_after_current=0
delete_block_after_commercial=0
min_commercial_break_at_start_or_end=39
always_keep_first_seconds=0
always_keep_last_seconds=0
[USA Specific]
intelligent_brightness=0
black_percentile=0.0076
uniform_percentile=0.003
score_percentile=0.71
[Main Scoring]
length_strict_modifier=3
length_nonstrict_modifier=1.5
combined_length_strict_modifier=2
combined_length_nonstrict_modifier=1
ar_wrong_modifier=2
ac_wrong_modifier=1
excessive_length_modifier=0.01
dark_block_modifier=0.3
min_schange_modifier=0.5
max_schange_modifier=2
logo_present_modifier=0.01
punish_no_logo=0
[Detailed Scoring]
punish=0
reward=0
punish_threshold=1.3
punish_modifier=2
reward_modifier=0.5
[Logo Finding]
border=10
give_up_logo_search=2000
delay_logo_search=0
logo_max_percentage_of_screen=0.12
ticker_tape=0
ticker_tape_percentage=0
top_ticker_tape=0
top_ticker_tape_percentage=0
ignore_side=0
ignore_left_side=0
ignore_right_side=0
subtitles=0
logo_at_bottom=0
logo_at_side=0
logo_threshold=0.8
logo_percentage_threshold=0.25
logo_filter=0
aggressive_logo_rejection=0
edge_level_threshold=5
edge_radius=2
edge_weight=10
edge_step=1
num_logo_buffers=50
use_existing_logo_file=0
two_pass_logo=1
[Logo Interpretation]
connect_blocks_with_logo=1
logo_percentile=0.92
logo_fraction=0.39
shrink_logo=5
shrink_logo_tail=0
before_logo=0
after_logo=0
where_logo=0
min_black_frames_for_break=1
[Closed Captioning]
ccCheck=0
cc_commercial_type_modifier=4
cc_wrong_type_modifier=2
cc_correct_type_modifier=1
[Live TV]
live_tv=0
live_tv_retries=6
require_div5=0
div5_tolerance=-1
incommercial_frames=1000
[Output Control]
output_default=1
output_chapters=0
output_plist_cutlist=0
output_zoomplayer_cutlist=0
output_zoomplayer_chapter=0
output_scf=0
output_vcf=0
output_vdr=1
output_projectx=0
output_avisynth=0
output_videoredo=0
output_videoredo3=0
videoredo_offset=2
output_btv=0
output_edl=1
output_live=0
edl_offset=0
timeline_repair=1
edl_skip_field=0
output_edlp=0
output_bsplayer=0
output_edlx=0
output_cuttermaran=0
output_mpeg2schnitt=0
output_womble=0
output_mls=0
output_mpgtx=0
output_dvrmstb=0
output_dvrcut=0
output_ipodchap=0
output_framearray=0
output_debugwindow=0
output_tuning=0
output_training=0
output_false=0
output_aspect=0
output_demux=0
output_data=0
output_srt=0
output_smi=0
output_timing=0
output_incommercial=0
output_ffmeta=1
output_ffsplit=1
delete_logo_file=1
output_mkvtoolnix=0
cutscene_frame=0
cutscene_threshold=10
[Sage Workarounds]
sage_framenumber_bug=0
sage_minute_bug=0
enable_mencoder_pts=0
[mpegts @ 0x807275600] Before avformat_find_stream_info() pos: 0 bytes read:32768 seeks:0 nb_streams:3
[mpegts @ 0x807275600] After avformat_find_stream_info() pos: 0 bytes read:1364112 seeks:2 frames:59
Input #0, mpegts, from '/media/DVR/TV/Superman & Lois/Superman & Lois S03E01 Closer 2023-03-14-2000.mpg':
  Duration: 01:00:59.83, start: 35080.868389, bitrate: 7837 kb/s
  Program 1024
    Stream #0:0[0x13f7]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv, top first), 1920x1080 [SAR 1:1 DAR 16:9], Closed Captions, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
    Stream #0:1[0x13f8](eng): Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, 5.1(side), fltp, 384 kb/s
    Stream #0:2[0x13f9](spa): Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, stereo, fltp, 192 kb/s
Frame Rate set to 29.970 f/s
Initial audio pts =      0.000
Initial video pts =      0.367
Initial video offset =      0.705 (video start = 35081.206, format start = 35080.868)
Format changed to [960 : 540]
Frame: 1	Ratio: 1.81	MinY: 1 MaxY: 540 MinX: 1 MaxX: 960
Frame: 1 Channels:  6
Resizing cc text array to accommodate 101 cc text groups.
Resizing scene change array to accommodate 2000 frames.
Frame    375 (12.446s) - Black frame with brightness of 16,uniform of 381 and volume of -737987527
Frame    376 (12.479s) - Black frame with brightness of 16,uniform of 381 and volume of -1
Frame    377 (12.513s) - Black frame with brightness of 16,uniform of 381 and volume of -1
Frame    378 (12.546s) - Black frame with brightness of 16,uniform of 381 and volume of -1
Frame    379 (12.579s) - Black frame with brightness of 16,uniform of 381 and volume of -1
XDS[412]:  1 83 d0 f2 ef 67 f2 61 6d 20 ce XDS[412]: Program Name: Program Name
XDS[480]: 85  1 ce e5 f4 f7 ef f2 6b 20 ce XDS[480]: Network Name: Network Name
Frame    529 (17.584s) - Black frame with brightness of 16,uniform of 378 and volume of 96
Frame    530 (17.618s) - Black frame with brightness of 16,uniform of 378 and volume of -1
Frame    531 (17.651s) - Black frame with brightness of 17,uniform of 391 and volume of -1
Frame: 532	Ratio: 2.17	MinY: 48	MaxY: 492	MinX: 1	MaxX: 960
Frame   1290 (42.976s) - Black frame with brightness of 16,uniform of 0 and volume of 113
Frame   1291 (43.010s) - Black frame with brightness of 16,uniform of 0 and volume of -1
Frame   1292 (43.043s) - Black frame with brightness of 16,uniform of 0 and volume of -1
Looking For Logo in frames 29 to 1450.
Not enough edge count - 0
Looking For Logo in frames 58 to 1479.
Frame   1504 (50.117s) - Black frame with brightness of 17,uniform of 144 and volume of 211
Frame   1505 (50.150s) - Black frame with brightness of 16,uniform of 143 and volume of -1
Frame   1506 (50.183s) - Black frame with brightness of 16,uniform of 144 and volume of -1
Frame   1507 (50.217s) - Black frame with brightness of 16,uniform of 144 and volume of -1
Frame   1508 (50.250s) - Black frame with brightness of 16,uniform of 144 and volume of -1
Looking For Logo in frames 87 to 1508.
Frame   1509 (50.284s) - Black frame with brightness of 16,uniform of 144 and volume of -1
Frame   1510 (50.317s) - Black frame with brightness of 16,uniform of 144 and volume of -1
Frame   1511 (50.350s) - Black frame with brightness of 16,uniform of 144 and volume of -1
Frame   1512 (50.384s) - Black frame with brightness of 16,uniform of 144 and volume of -1
Frame   1513 (50.417s) - Black frame with brightness of 16,uniform of 144 and volume of -1
Frame   1514 (50.450s) - Black frame with brightness of 16,uniform of 144 and volume of -1
Frame   1515 (50.484s) - Black frame with brightness of 16,uniform of 144 and volume of -1
Frame   1516 (50.517s) - Black frame with brightness of 16,uniform of 144 and volume of -1
Frame   1517 (50.551s) - Black frame with brightness of 16,uniform of 144 and volume of -1
Frame   1518 (50.584s) - Black frame with brightness of 16,uniform of 144 and volume of -1
Frame   1519 (50.617s) - Black frame with brightness of 16,uniform of 144 and volume of -1
Frame   1520 (50.651s) - Black frame with brightness of 16,uniform of 144 and volume of -1
Frame   1521 (50.684s) - Black frame with brightness of 16,uniform of 144 and volume of -1
Frame   1522 (50.717s) - Black frame with brightness of 16,uniform of 144 and volume of -1
Frame   1523 (50.751s) - Black frame with brightness of 17,uniform of 141 and volume of -1
Frame   1524 (50.784s) - Black frame with brightness of 17,uniform of 141 and volume of -1
Frame   1525 (50.817s) - Black frame with brightness of 17,uniform of 140 and volume of -1
Frame   1526 (50.851s) - Black frame with brightness of 17,uniform of 140 and volume of -1
Frame   1527 (50.884s) - Black frame with brightness of 17,uniform of 140 and volume of -1
Frame   1528 (50.918s) - Black frame with brightness of 17,uniform of 140 and volume of -1
Frame   1529 (50.951s) - Black frame with brightness of 17,uniform of 140 and volume of -1
Frame   1530 (50.984s) - Black frame with brightness of 17,uniform of 140 and volume of -1
Frame   1531 (51.018s) - Black frame with brightness of 17,uniform of 140 and volume of -1
Frame   1532 (51.051s) - Black frame with brightness of 17,uniform of 140 and volume of -1
Frame   1533 (51.084s) - Black frame with brightness of 17,uniform of 140 and volume of -1
Frame   1534 (51.118s) - Black frame with brightness of 17,uniform of 140 and volume of -1
Frame   1535 (51.151s) - Black frame with brightness of 17,uniform of 141 and volume of -1
Frame   1536 (51.184s) - Black frame with brightness of 17,uniform of 142 and volume of -1
Frame   1537 (51.218s) - Black frame with brightness of 17,uniform of 226 and volume of -1
Looking For Logo in frames 116 to 1537.
Frame   1538 (51.251s) - Black frame with brightness of 17,uniform of 318 and volume of -1
Frame   1539 (51.285s) - Black frame with brightness of 17,uniform of 405 and volume of -1
Frame   1540 (51.318s) - Black frame with brightness of 18,uniform of 459 and volume of -1
Frame   1541 (51.351s) - Black frame with brightness of 18,uniform of 475 and volume of -1
Looking For Logo in frames 145 to 1566.
Looking For Logo in frames 174 to 1595.
Looking For Logo in frames 203 to 1624.
Looking For Logo in frames 232 to 1653.
Looking For Logo in frames 261 to 1682.
Looking For Logo in frames 290 to 1711.
Looking For Logo in frames 319 to 1740.
Looking For Logo in frames 348 to 1769.
Looking For Logo in frames 377 to 1798.
Looking For Logo in frames 406 to 1827.
Looking For Logo in frames 435 to 1856.
Looking For Logo in frames 464 to 1885.
Looking For Logo in frames 493 to 1914.
Looking For Logo in frames 522 to 1943.
Looking For Logo in frames 551 to 1972.
Looking For Logo in frames 580 to 2001.
Looking For Logo in frames 609 to 2030.
Looking For Logo in frames 638 to 2059.
Looking For Logo in frames 667 to 2088.
Looking For Logo in frames 696 to 2117.
Looking For Logo in frames 725 to 2146.
Looking For Logo in frames 754 to 2175.
Looking For Logo in frames 783 to 2204.
Looking For Logo in frames 812 to 2233.
Looking For Logo in frames 841 to 2262.
Looking For Logo in frames 870 to 2291.
Looking For Logo in frames 899 to 2320.
Looking For Logo in frames 928 to 2349.
Looking For Logo in frames 957 to 2378.
Looking For Logo in frames 986 to 2407.
Looking For Logo in frames 1015 to 2436.
Looking For Logo in frames 1044 to 2465.
Looking For Logo in frames 1073 to 2494.
Looking For Logo in frames 1102 to 2523.
Looking For Logo in frames 1131 to 2552.
Looking For Logo in frames 1160 to 2581.
Looking For Logo in frames 1189 to 2610.
Looking For Logo in frames 1218 to 2639.
Looking For Logo in frames 1247 to 2668.
Edge count - 2093	Percentage of screen - 0.75%, Check: 0
Double checking - 1
Looking For Logo in frames 1276 to 2697.
Edge count - 2106	Percentage of screen - 0.75%, Check: 1
Double checking - 2
Doublechecking frames 1276 to 2697 for logo.
Logo not present in frame 1276.
7890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567
467:
468:
469:
470:
471:                  ------------          ---------          --------          --------
472:                ------------------       --------          --------          --------
473:              -------------------+ |  ||+++----++||      ||+-----++||      ||++----++||
474:             -++++--------------++||  |||++----++||      ||++----++||      ||++----++||
475:           -++++----          - ||||   ||||    ||||      ||||    ||||      ||||    |||||
476:           ++++--               ||||  |||||    ||||      ||||    ||||      ||||    ||||
477:         |++-+                  ||||  |||||    ||||     |||||    ||||      ||||    |||||
478:        |+++-                   ||||  |||||    ||||     |||||    ||||      ||||    ||||
479:        |+++         -----------++||  |||||    ||||     |||||    ||||      ||||    |||||
480:       |+++|      --------------++||  |||||    ||||      ||||    ||||      ||||    ||||
481:       |++|      -----------------    |||||    ||||      ||||    ||||      ||||    ||||
482:      ||++|     |++-+-------------    |||||    ||||      ||||    ||||      ||||    |||||
483:      ||+|     |++++- - -------       |||||    ||||      ||||    ||||      ||||    ||||
484:      |+||    ||+|| ------  - ----    |||||    ||||      ||||    ||||      ||||    ||||
485:      ||||    ||++   --  -  - --      |||||    ||||      ||||    ||||      ||||    ||||
486:     ||+||    |++| |+-+-++||++-+++     ||||    ||||      ||||    ||||      ||||    ||||
487:     ||+||    |++| |+++++++|++++||    |||||    ||||      ||||    ||||      ||||    |||||
488:     |||||   ||+|| |++|++|+++|||++||  ||+||    ||||     |||||    |||||     ||||    |||||
489:     ||+||   ||++| |++++++++++++++    ||+||    ||||     |||||    |||||     ||||    |||||
490:     ||+||   ||++| ||++||+++++++++||  |++||    ||||     |||||    |||||     ||||    |||||
491:     ||+||    |+++  |++| +++-+++++||  |++||    ||+|     ||+||    ||+||     |+||    |||||
492:     ||++|    |++++  --  -  ------   ++++|     ||+|     |++||    ||++|    ||+||    |++||
493:     ||++|     |+++-- -  -  - ----  -++++      ||++|    +++||    ||+++    |++||    |++||
494:      |+++|    |+++++--------------+++++|      ||+++---++++|      |++++---+++|     |++|
495:      |+++|      ++++++-----------+++++         |++++++++++       |++++++++++|    |+++|
496:       |+++|     ----------------------          -++++++++          ++++++++      |++||
497:       |++++       ------------------             -------            ------      |+++|
498:        |++++                              --       ----      --      ----       ++++|
499:         +++++                            ----               ----               ++++|
500:          +++++-                        -++++++-           -++++++-           -+++++
501:           +++++--                    --++++++++--       --++++++++--       --+++++
502:            ++++++--------------------+++++-++++++-------++++++++++++-------++++++
503:             -++++++----------------++++++-  -++++++---++++++-  -++++++---++++++-
504:              ---++++++----------++++++---    --++++++++++---    ---+++++++++---
505:                ------------------------        -----------        -----------
506:                   ------------------              -----              -----
507:
508:
509:
510:
I wish I could be more help
Please try this new build to see if there is any improvement.
I've been using a Windows 10 laptop as my server while waiting for a fix. I disconnected the laptop. Then I started the TrueNAS jail which came up fine. I updated to the latest version, also fine. Then started to restore the database and when I pointed to the storage received:
A Javascript error has occurred!
Please refresh the browser after reporting this issue on Channels Community or to [email protected].
Minified React error #310; visit https://reactjs.org/docs/error-decoder.html?invariant=310 for the full message or use the non-minified dev environment for full errors and additional helpful warnings.
[email protected]http://192.168.2.20:8089/node_modules/react-dom/cjs/react-dom.production.min.js:158
[email protected]http://192.168.2.20:8089/node_modules/react-dom/cjs/react-dom.production.min.js:159
[email protected]http://192.168.2.20:8089/node_modules/react-dom/cjs/react-dom.production.min.js:174
[email protected]http://192.168.2.20:8089/node_modules/react/cjs/react.production.min.js:23
[email protected]http://192.168.2.20:8089/admin/components/settings/LocalContent.jsx:15
[email protected]http://192.168.2.20:8089/node_modules/react-dom/cjs/react-dom.production.min.js:157
[email protected]http://192.168.2.20:8089/node_modules/react-dom/cjs/react-dom.production.min.js:180
[email protected]http://192.168.2.20:8089/node_modules/react-dom/cjs/react-dom.production.min.js:269
[email protected]http://192.168.2.20:8089/node_modules/react-dom/cjs/react-dom.production.min.js:250
Please advise
Just to see where things are at, I opened the web interface again and it looks normal. I ran a redetect commercials and got the same error:
2023/03/22 19:44:49.541162 [DVR] Running commercial detection on file 2100 (TV\Quantum Leap\Quantum Leap S01E16 Ben Interrupted 2023-03-20-2200.mpg)
2023/03/22 19:44:51.122623 [DVR] Commercial detection failed for TV\Quantum Leap\Quantum Leap S01E16 Ben Interrupted 2023-03-20-2200.mpg with signal: abort trap
Thank you for your efforts. I'm going to switch back to my very slow laptop (commercial skipping is 4 times slower and transcoding impossible) and will be happy to test any time you ask.
Morris
I too am still getting "abort trap" errors on commercial editing attempts. Detection appears to be working for me, it is just editing to get verified status that fails with the broken images in the editor interface.
@terryD are you getting the broken images with every single recording, or just some?
every recording that has not been previously verified.
@Morris_Altman are you also seeing broken images in the commercial verifier?
here is the error message from log if it helps:
2023/03/22 16:47:56.034806 [ERR] Failed to generate preview @ 3697.9: signal: abort trap
that is just one of many per recording.
