I've been able to use the [MTS} stats highest_pts to determine the interruption point on most recordings.
Problem is when two back-back overlapping recordings share a channel, the stats are wrong for highest_pts as it seems to reflect time starting with the first recording.
Any possibility this can be fixed?
EXAMPLE
2022/07/01 20:00:15.649306 [MTS] Statistics for "TV/Hogan's Heroes/Hogan's Heroes S01E29 1966-04-08 The Assassin 2022-07-01-1928.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=0 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=true saw_pmt=true highest_pts=3735.604622
From dvr log
2022/07/01 18:58:00.004045 [DVR] Starting job 1656727080-39 Hogan's Heroes on ch=[9001]
2022/07/01 18:58:02.995696 [TNR] Opened connection to M3U-frndlyTV for ch9001 MeTV
2022/07/01 18:58:03.030117 [DVR] Recording for job 1656727080-39 from M3U-frndlyTV ch9001 into "TV/Hogan's Heroes/Hogan's Heroes S01E28 1966-04-01 I Look Better in Basic Black 2022-07-01-1858.mpg" for 33m59.984882565s
2022/07/01 19:00:14.216822 [ERR] Error during stream M3U-frndlyTV ch9001 MeTV: Failed to download file: https://sr-live2-frndly.akamaized.net/v1/manifest/segment/840a24ccd7c75076211d060179b3ad0c64fdc6ca/live_v2_nr_new/1e798c16-0af7-4d0c-9986-73dafca212a4/0/1453513: 404 Not Found
2022/07/01 19:00:14.457430 [MTS] Statistics for "TV/Hogan's Heroes/Hogan's Heroes S01E28 1966-04-01 I Look Better in Basic Black 2022-07-01-1858.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=0 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=true saw_pmt=true highest_pts=134.333333
2022/07/01 19:00:14.574147 [TNR] Closed connection to M3U-frndlyTV for ch9001 MeTV
2022/07/01 19:00:14.590877 [DVR] Job 1656727080-39 Hogan's Heroes ended prematurely: 31m45.409143654s
2022/07/01 19:00:14.697751 [DVR] Starting job 1656727080-39 Hogan's Heroes on ch=[9001]
2022/07/01 19:00:15.881520 [TNR] Opened connection to M3U-frndlyTV for ch9001 MeTV
2022/07/01 19:00:15.881665 [DVR] Recording for job 1656727080-39 from M3U-frndlyTV ch9001 into "TV/Hogan's Heroes/Hogan's Heroes S01E28 1966-04-01 I Look Better in Basic Black 2022-07-01-1858.mpg" for 31m45.3020434s
2022/07/01 19:28:00.054936 [DVR] Starting job 1656728880-39 Hogan's Heroes on ch=[9001]
2022/07/01 19:28:00.085408 [TNR] Sharing existing connection to M3U-frndlyTV for ch9001 MeTV (clients=2, len=0)
2022/07/01 19:28:00.134561 [DVR] Recording for job 1656728880-39 from M3U-frndlyTV ch9001 into "TV/Hogan's Heroes/Hogan's Heroes S01E29 1966-04-08 The Assassin 2022-07-01-1928.mpg" for 33m59.932085206s
2022/07/01 19:32:00.225867 [MTS] Statistics for "TV/Hogan's Heroes/Hogan's Heroes S01E28 1966-04-01 I Look Better in Basic Black 2022-07-01-1858.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=0 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=true saw_pmt=true highest_pts=2056.431289
2022/07/01 19:32:00.244308 [DVR] Finished job 1656727080-39 Hogan's Heroes
2022/07/01 20:00:15.509024 [ERR] Error during stream M3U-frndlyTV ch9001 MeTV: Failed to download file: https://sr-live2-frndly.akamaized.net/v1/manifest/segment/840a24ccd7c75076211d060179b3ad0c64fdc6ca/live_v2_nr_new/458149aa-a7d4-4d02-b034-8649a5471c35/0/1454114: 404 Not Found
2022/07/01 20:00:16.447343 [TNR] Closed connection to M3U-frndlyTV for ch9001 MeTV
2022/07/01 20:00:16.447446 [DVR] Job 1656728880-39 Hogan's Heroes ended prematurely: 1m43.552568529s
2022/07/01 20:00:16.671915 [DVR] Starting job 1656728880-39 Hogan's Heroes on ch=[9001]
2022/07/01 20:00:18.115089 [TNR] Opened connection to M3U-frndlyTV for ch9001 MeTV
2022/07/01 20:00:18.115394 [DVR] Recording for job 1656728880-39 from M3U-frndlyTV ch9001 into "TV/Hogan's Heroes/Hogan's Heroes S01E29 1966-04-08 The Assassin 2022-07-01-1928.mpg" for 1m43.32786653s
2022/07/01 20:02:00.147404 [TNR] Closed connection to M3U-frndlyTV for ch9001 MeTV
2022/07/01 20:02:00.321255 [MTS] Statistics for "TV/Hogan's Heroes/Hogan's Heroes S01E29 1966-04-08 The Assassin 2022-07-01-1928.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=0 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=true saw_pmt=true highest_pts=3852.471289
2022/07/01 20:02:00.321486 [DVR] Finished job 1656728880-39 Hogan's Heroes
