DirectTV channels are not all authenticated
I'm connecting to the Direct TV and I am getting many channels that are showing up Cable provider authentication failed. I rescan multiple times, and it a few may then authenticate...but channels I've had in the past keep failing
This has been happening to me as well. Initial scan get the majority of channels, especially the freebies included with every TVe sub, but i have to go back and manually scan a lot of the channels. It's all over the place as far as providers, not limited to a particular provider.
Might get more traction posting in the DirecTV TVe thread: Provider - DirecTV
It looks like the page is just timing out for some reason.
2023/01/17 19:15:57.090982 [TVE] action=auth mvpd=DTV requestor=usa
2023/01/17 19:15:57.525416 [TVE] action=version product=HeadlessChrome/109.0.5414.74 jsVersion=10.9.194.9 protocol=1.3 revision=@e7c5703604daa9cc128ccf5a5d3e993513758913
2023/01/17 19:15:57.527103 [TVE] action=navigate url=https://sp.auth.adobe.com/adobe-services/authenticate/saml?noflash=true&mso_id=DTV&requestor_id=usa&no_iframe=true&domain_name=adobe.com&redirect_url=https%3A%2F%2Fsp.auth.adobe.com%2Fadobe-services%2FcompletePassiveAuthentication
2023/01/17 19:15:57.528541 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/authenticate/saml
2023/01/17 19:15:57.859900 [TVE] action=wait_for_page
2023/01/17 19:15:57.880337 [TVE] action=request type=Document method=POST url=https://idp.dtvce.com/dtv-idp-authn/authn/v2
2023/01/17 19:15:57.880373 [TVE] action=auth_domain domain=idp.dtvce.com
2023/01/17 19:15:58.493911 [TVE] action=request type=Document method=GET url=https://oidc.idp.clogin.att.com/mga/sps/oauth/oauth20/authorize
2023/01/17 19:15:58.568859 [TVE] action=request type=Document method=GET url=https://signin.att.com/dynamic/iamLRR/LrrController
2023/01/17 19:16:06.961632 [TVE] action=page_ready
2023/01/17 19:16:06.961704 [TVE] action=wait_for_page done=true reason=page_ready
2023/01/17 19:16:06.961749 [TVE] action=fill_form u=**************
2023/01/17 19:16:07.504155 [TVE] action=wait_for_auth timeout=12s
2023/01/17 19:16:07.668173 [TVE] action=request type=Document method=POST url=https://oidc.idp.clogin.att.com/mga/sps/authsvc
2023/01/17 19:16:07.708302 [TVE] action=request type=Document method=GET url=https://signin.att.com/dynamic/iamLRR/LrrController
2023/01/17 19:16:13.777578 [TVE] action=page_ready
2023/01/17 19:16:13.788017 [TVE] action=click_interstitial
2023/01/17 19:16:25.791224 [TVE] action=auth_timed_out
2023/01/17 19:16:25.791285 [TVE] action=screenshot
2023/01/17 19:16:25.915899 [TVE] action=screenshot size=30446
2023/01/17 19:16:25.916310 [TVE] action=capture_html
2023/01/17 19:16:25.919849 [TVE] action=capture_html size=6681
And you just keep trying and eventually it just works
2023/01/17 19:18:33.331243 [TVE] action=auth mvpd=DTV requestor=usa
2023/01/17 19:18:33.802316 [TVE] action=version product=HeadlessChrome/109.0.5414.74 jsVersion=10.9.194.9 protocol=1.3 revision=@e7c5703604daa9cc128ccf5a5d3e993513758913
2023/01/17 19:18:33.804254 [TVE] action=navigate url=https://sp.auth.adobe.com/adobe-services/authenticate/saml?noflash=true&mso_id=DTV&requestor_id=usa&no_iframe=true&domain_name=adobe.com&redirect_url=https%3A%2F%2Fsp.auth.adobe.com%2Fadobe-services%2FcompletePassiveAuthentication
2023/01/17 19:18:33.805920 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/authenticate/saml
2023/01/17 19:18:34.325051 [TVE] action=wait_for_page
2023/01/17 19:18:34.356405 [TVE] action=request type=Document method=POST url=https://idp.dtvce.com/dtv-idp-authn/authn/v2
2023/01/17 19:18:34.356470 [TVE] action=auth_domain domain=idp.dtvce.com
2023/01/17 19:18:34.996349 [TVE] action=request type=Document method=GET url=https://oidc.idp.clogin.att.com/mga/sps/oauth/oauth20/authorize
2023/01/17 19:18:35.073912 [TVE] action=request type=Document method=GET url=https://signin.att.com/dynamic/iamLRR/LrrController
2023/01/17 19:18:42.375151 [TVE] action=page_ready
2023/01/17 19:18:42.375248 [TVE] action=wait_for_page done=true reason=page_ready
2023/01/17 19:18:42.375269 [TVE] action=fill_form u=*************
2023/01/17 19:18:42.967202 [TVE] action=wait_for_auth timeout=12s
2023/01/17 19:18:43.146176 [TVE] action=request type=Document method=POST url=https://oidc.idp.clogin.att.com/mga/sps/authsvc
2023/01/17 19:18:43.459263 [TVE] action=error_response type=XHR error=net::ERR_ABORTED url=https://att-app.quantummetric.com/
2023/01/17 19:18:43.479116 [TVE] action=request type=Document method=POST url=https://api.cld.dtvce.com/idp/login
2023/01/17 19:18:43.923960 [TVE] action=request type=Document method=POST url=https://sp.auth.adobe.com/sp/saml/SAMLAssertionConsumer
2023/01/17 19:18:44.026238 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/completePassiveAuthentication
2023/01/17 19:18:44.026267 [TVE] action=authed
2023/01/17 19:18:44.029304 [TVE] action=cookies num_domains=2 num_cookies=5
2023/01/17 19:18:44.030523 [TVE] action=error_response type=Document error=net::ERR_ABORTED url=https://sp.auth.adobe.com/adobe-services/completePassiveAuthentication
Just annoying when you have to go in and manually scan them one at a time because the 'Recan New Channels' option doesn't work.
yes, had to manually do each channel not coming in...sometimes having to do those channels 3 or 4 times before they are authenticated....it took time, but they are working....not sure why it kind of just started though...used to pick up all channels.
Doing the same now....quite a few have gone dumb for some reason.
