Running 2024.12.04.1929, getting “no login form found” for 40+ TVE channels. Tried updating to latest pre-release and rescanning source. Any help is appreciated!
Logs have been submitted as 35e19b0d-3571-4ec3-b0a7-d5fa5bc22a0f
I am having the same issue with DirecTV too.
Yes and now I can't setup TVE for DirecTV and here is my logs: 1d2310cb-ab19-4c0d-9576-7f1266fe58dd
There is a thread going about TVE issues. I suggest you join it:
I did as I posted just before you did in that topic
Thank you
I am running the official docker image. The issue pre-dates the 12/5 server update. I was running the September release when the TVE issue appeared, so I updated the version to the most recent pre-release as a troubleshooting step. I’m guessing the authentication method/url for a portion of the stations has changed and needs to be updated. Hopefully we get some feedback from the developers soon.
I am running the Windows version and I have been having the issue for a couple weeks.
This is being looked into.
Please try the latest pre-release and let us know if it resolves the issue for you.
This release fixed my issue in combination with adding 4 entries to my DNS filter’s whitelist. I guess a fair number of stations changed their telemetry partners?
You’re on your own if you use any DNS ad blocker in front of your DVR. We attempt to tell you in Troubleshooting about commonly blocked hostnames but the list is not complete. Blocking connections made by the DVR and TVE can only cause pain.
