TVE Troubleshooting tips
Troubleshooting steps to follow, like a checklist. No need to do every step if one fixes the issue.
Refresher: How Channels DVR TVE works
  1. If you can't watch the network at their Live streaming website, nothing Channels can do. Like nbc.com/live or the networks check availability buttons at Channels Support - TV Everywhere Availability for your Provider
  2. Make sure your package or container (if running in one) is up to date.
  3. Update to the latest DVR prerelease version see this article for how
  4. Run troubleshooting from the DVR web UI Support>Troubleshooting and make sure all green checkmarks. (If it says Chrome corrupted or not up to date, it should offer a green fix button to click.)
  5. Make sure your chrome or headless chrome is up to date. (Troubleshooting in step 4 should show)
  6. Disable any ad blocker extensions running in your browser, see user post Recent Xfinity TVE auth failure - #3 by brownpeel
  7. Try playing the failing channel a few times to see if it will re-authenticate (I do this in the web UI).
  8. Close all browser windows and open a new private/incognito browser window to access your dvr (Some users had to access the DVR web UI remotely or using secure HTTPS to add a source)
  9. Open a second tab in the same browser window and login to nbc.com/live, dismiss any popups/notifications your provider may display on login, but take note of them as this may cause an issue when Channels DVR does it.
  10. Before rescanning individual channels, and before removing a source to re-add, use Update Password under the gear dropdown next to your source in the DVR web UI and just key in your existing Provider password to clear the chromedata folder (likely used with other providers, but known to be used for Spectrum and Xfinity per this post)
  11. If adding a TVE source, click and HOLD the Login button.
  12. Individually rescan channels with issues using Rescan Channels under the gear dropdown next to your source in the DVR web UI.
  13. Reboot your server or restart your package or container if running in one.
  14. If all the above fails, submit DVR diagnostics from the DVR web UI Support>Troubleshooting.
  15. Remove and re-add your source, then individually rescan any channels with issues. WARNING: If this step fails, you might lose all your TVE channels.
More tips in the following posts
TVE losing Discovery owned channels
Many channels went to notAuthorized
Xfinity TVE - Cable provider authentication fails
Spectrum Playback Issues
Provider - Xfinity
Fox TVE 6002
Provider - DirecTV
Context Canceled error
Provider - Xfinity
BIG10 & FS1/FS2 - not entitled: mvpd: Resource is not supported by MVPD
Can't authenticate to DIY network with Spectrum
Discovery channels not connecting - "no login form found"
Provider - Xfinity
Pluto TV link
What Happened to FS1 & Big Ten Network?
Not Authorized Local Channels
Provider - Xfinity
NFL Network "Cable provider authentication failed" December 2022
Is the Science Channel on TVE having issues for anyone else?
Provider - Hulu Live TV
TV Everywhere Mediacom Discovery Network channels
Discovery channels not tuning on YTTV
Synology keeps stopping Channing DVR from running
Xfinity won't add as source...Not In Subscription
TV Everywhere Issue - Losing Channels
Provider - DirecTV Stream
No Login Form Found
XFinity TVE can't login to some channels
Provider - YouTube TV
Xfinity TVE not working....again
FS1 TVE channel disappeared
Spectrum Cable provider authentication failed
Spectrum no longer working
TVE No longer works on any channels
Xfinitiy Login Issues
Direct TV TVE "No Login Form Found"
Provider - Sling TV
Missing Warner Brothers owned TV Channels w/ DirecTV Stream
Philo help! 7.7.23
Xfinity TVE Error
DirecTV Stream Discovery Channels gone?
DirecTV TVE not working
Authentication Failed
Can't get ABC TVE with Dish or Directv
FS1 and 2 gone
Discovery channels not authenicating w/ YTTV
Fox TVE 6002 not working
Directv Stream & NFL Network/ RedZone
Discovery Channel
Nothing below 6101 Channel will tune in - Spectrum
Cannot authenticate Xfinity anymore
Direct TV: Authn: 401 : Data not found
NFL network Frontier
Provider - Xfinity
Erratic TV Everywhere (TVE) authentication failures
Recordings are failing!
No Foxnews or History today
Multiple TVE issues with YTTV and Philo
Provider - Xfinity
Fios login problems
Dish TVE - No Login Form Found
DirecTV - No Login Form Found
Provider - FuboTV
Provider - Xfinity
Discovery Channel Not Showing Up, But All Other Discovery Channels Do - Spectrum TV
Fios TVE NAS VPN
Missing ESPN on Verizon Fios
TVEverywhere failure
Xfinity log in issues?
Provider - Xfinity
Where can I see my TVE account credentials in Channels?
DirecTV Not Connecting
Provider - Xfinity
Scanning channels
Losing TVE channels, multiple providers
TVE via YouTube TV gone?
Chrome failed to start: TVE Authentication
Xfinity TVE on the blink again?
FS2 not authenticating with YTTV
Whence TVE?
Experimental: Local Networks (NBC, ABC, FOX) in some major metros via TVE
Provider - Verizon Fios
Auth failed for Comcast_SSO: Cable provider authentication failed
Most channels not working
I just had Ziply Fiber installed using Xfinity Comcast cable and want to add YTTV
Provider - Xfinity
Optimum Provider - TVE source won't authenticate
Cannot login to Fios TV Everywhere
Direct TV Streaming - no login form found error
TVE and Philo stopped working yesterday
DirecTV TVE websocket url timeout reached
Lost most TVE channels
Disney ABC Shutting down stand alone apps
TV Everywhere not bringing in Spectrum channels
Latest update breaks TVE
Spectrum TVE wont authenticate
DirecTV Stream not working with TVE?
DirecTV Stream on TVE issues
YouTube TV TVE Broken?
Unable to add Cox TVE as source
Cable Provider Authenication Failed (Youtube TV)
TBS via TVE
TVE - Hulu Not Authenticating
All TVE channels failing for Philo
TVE fails to authenticate with Xfinity
Another "Blocked by Xfinity" problem using Xfinity Now
Reelz TVE no longer available
Discovery via Charter/Spectrum authentication
NFL Network "no login form found"
History Down
NFL Network Not Working “no login form found” You tube TV
Invalid Token on Discovery Channels
Fubo TV project
Provider - Sling TV
TVE National Geographic and Fox News
Provider - Xfinity
Authz: 400 Bad Request For TBS, TRU TV, and Cartoon Network (Spectrum)
DirecTV Stream Won't Authenticate
TVE support not working for WBBM (CBS Chicago)
Destination America 403 Error
Xfinity wont log in
TVE - no TLC on Xfinity
Xfinity TVE failing to auth
Unable to add YouTubeTV as TVE provider
Issues with TVE
Authz:400 bad request: bad request
Authentication Errors with Discovery Channels (YTTV)
Some questions about YouTube TV
Provider - Xfinity
Science Channel Not working
Provider - Xfinity
Some other tips.
  • If running in a container, use the TVE container Docker Hub
  • Using a VPN or geo-location blocker is not supported. Disable these temporarily when adding a TVE source or scanning channels.
  • Use a secondary provider account with 2FA/MFA/Recovery options disabled.
  • Some users report that changing their password with their provider fixed auth issues.
  • If using Xfinity as a provider, see the next two posts about their auto-authentication setting and the Viewer role account.
Xfinity auto-auth setting at https://idm.xfinity.com/myaccount/userprofile (login there with your Primary user account id/name)
Listed as a Note in the first post of this topic Provider - Xfinity that it needs to be OFF If you have separate Xfinity logins for TV and Internet.
See this post for when you should leave it ON
Although I have both Xfinity TV and Internet, it works better for me when it's OFF.
If your Provider is Xfinity, use a secondary Viewer role account for Channels DVR
and use the username, not [email protected] for Channels DVR TVE.
