I have DirecTV with the dish and receiver and am able to use it as a TVE source. It works pretty well. The dish is actually located at my second home in Maine where I rarely am at. I access DirecTV using TVE via ChannelsDVR here in Maryland. I think this is fair and reasonable as I cannot be at two locations at the same time.
I am curious if anyone has had the actual satellite service and then dropped it and went with DirectTV Stream? I am told I can get the local channels - presumably, those where the billing address is located (or maybe I select a zip code?).
Since I use ChannelsDVR as my primary TV viewing tool, does anyone have any concerns making the switchover from satellite to DirecTV Stream? Any considerations?
