Had this issue in the past and removing the source and re-adding fixed it. Not this time though, still can't seem to get the B10 network or Fox1 / Fox2 Sports. Did they drop TVE, or does this error mean anything?
Did you follow any of these steps?
You can also watch these channels on Eplus or Prismcast as they're not DRM'd if you need a backup solution
I may fire up ETVplus again. That might be the easiest fix. Thank you for the feedback.
