Hi,
Remote Access used to work. Don’t know what happened, neither iOS app nor web remote access works. I even tried my.channel.net:8089! I have not modified the port forwarding part, the 8089 port forwarding setting is still in the router. If I access my DVR locally using Safari or Chrome browsers, it works! Just the remote access is having problem. BTW, I have other port forwarding to the same server, those Apps are working fine. Just Channel DVR 8089 is not working.
Should I restart Channel DVR?
Thanks,
Roger
