DVR on another port
Definitely playground...
But on my little linux box I run my normal channels-dvr but I am testing another instance of channels-dvr in a docker container [rational not all that important, but multiple people in my household noodling with the test dvr leaving the primary alone] at the same time exposed from the container 8090 from the app's 8089. I can manage both via admin/browser just fine.
Is there an easy way to allow the Channels clients to connect to this Docker instance on a different port while also allowing the client to be access the standard 8089 port? I would like to be able to switch easily.
The only rube-goldberg way I have come up so far is to also run a socat listener on a different nic & ip listening for 8089 that bridges it to 8090.
Would be simpler if the clients could handle a port other than the default.
Thoughts on any better way to accomplish this?
If you run multiple dvrs are home, turn off bonjour discovery, and just connect the clients manually via ip and port.
Just put the port at the end of the ip.
192.168.1.50:8088
Yes @ home.
Alas I swore I tried that and it kept going to 8089 (was trying on Shield).
Now trying on ios and it works!
Thanks.
