DVR Pre-Release Build: Web Player Re-design (v2017.05.03.2306)
Can you email me a screenshot to [email protected]
The cc fix didn’t work for synology. It just shows ā€˜unknown’.
Does the button say CC or subtitles?
How about with software transcoding?
What browser?
It shows a CC button. It used to not appear at all when using hardware transcode. Now the hardware transcode shows the CC button, but the only options are off or unknown. The software transcode is too slow so I don’t use it, but I did test this before the most recent update and it used to work with software transcode. Now (after update) it is the same as the hardware option. A CC button, but without the correct option for English subtitles.
EDIT: using Safari. Also tested using Chrome: With Chrome there is no option at all when using hardware. Software transcode does work, though.
Don’t know when this started, but I was on my iPhone watching a recording, from the fly out window with the player is also the settings cog. I clicked delete and got the popup to delete but the screen didn’t take me back to the episode listing for the show, it stuck there. A refresh of the screen fixed it.
Confirmed that the Linux hardware transcoder does not copy closed captions. This is the same issue as on windows in No CC on hardware transcoding
I had enabled closed caption passthrough on the macOS hardware transcoder, but had to disable it again in v2017.05.07.1905 because of stalling bugs. I was able to gather more data on the bug so perhaps we’ll be able to fix it soon.
Fixed in v2017.05.12.0136
