With v2022.08.29.2159, TVE and custom channels which are unmapped will get placeholder guide data assigned automatically.
The art, title and description are inherited from the Custom Channel properties (i.e. tvc-guide-title).
A separate "series" is created per hour, so you can setup a pass directly from the guide for a specific hour block. You can also use advanced pass rules to limit to certain days of the week. Advanced pass editor on the web UI also allows for negative padding, if you want to record less than 60 minutes.
h/t to @chDVRuser for the idea and previous experiments with manual recordings
