Enhanced Library not showing on Echo Show 15
I've got an Echo Show (15") that we use in our kitchen and Channels works on it. However, one minor issue is that Enhanced Library doesn't work at all - it just display the regular library. I have tried setting it in the client and forcing it from the server. The client says its enabled but it never works.
Assuming there's some sort of setting in the code that prevents it from being used in certain scenarios? Any logging or anything I can submit?
