If everything works for me, only MLB doesn't.
MLB.tv has been kind of funky. The problem seems to occur during spring training. I think it will do what is needed once the season gets underway.
What does your logs say?
The new sny and mlbtv integration works great through e+. And my mlb account is not active and it still works even though regular mlbtv games don’t work. No need to add sny for me anymore. Thanks.
1080p60 should look great! You might have convinced me. LGM!
Does it filter out the games you don't have access to?
No, they still appear in the guide but they don’t play, they error out.
If you share your login I can see if I can check which ones you have access to
Yeah...I'm having the same issues too. The free games aren't being filtered. Those are the only games I can see so it doesn't make much sense for the other games to show
Do you have it set to only grab free games?
Yes
Do I need to reset the token or...
No, I'll look and see what's going on
Okay Ive been having a weird transcoding issue.
If I stream eplustv through channelsdvr it crashes after a while with a transcoder reset error.
If I stream that same eplustv through another player like VLC or IPTV smarter it works even when it stops the stream. I have to figure out how to fix this issue. Is it hardware related?
How do I fix this.
My setup:
Eplustv through Linux server running on docker with portainer.
Channelsdvr running on macos Intel.
Do I just retire the channelsdvr server on macos and move it to another mini PC I have. Bluebubbles was the main reason I had a Mac mini but with rcs this is no longer needed.
EDIT: It has the same issue with IPTV Smarters Pro and VLC it seems but it just plays again from that spot after a playback failed error.
To follow up on this its happening exactly when a commercial break ends.
Can we get SNLA plus added to the container?
I live in the l.a. market and paid for a month of it.
They are using MLB.tv stuff to push it.
Let me know if i can help on this end.
Do you mean this?
Are they doing stuff besides MLB? If not you should just be able to authenticate there with your account and it should work. If they have other sports then yeah I can look at adding it
Looks like it may be a static channel. it is like how they did with SNY.
I got a month to try it out.
Actually it doesnt affect commercial break. However I noticed it affects every channel.
Edit: now its every channel. Even a full reset doesnt fix this timeout issue.
Thanks - this looks what I'm looking for. I'm about to purchase Channels and get a BeeLink miniPC to sue as the server. However, my primary use is for the Gotham Sports App (MSG network) - can anyone confirm that it currently works and does so regularly. I had Channels in the past and connected to MSG and it worked great, then stopped, then started working again, and then stopped working - so I got rid of Channels. I just want to MSG/Gotahm works consistently before investing into this. TIA
I'm coming back to this after a while and the new UI is a game changer. Thanks! Is there a chance we could get March Madness Live added to this? It has a few linear channels, but it also provides access to games through a TV provider. Watch March Madness Live on NCAA | NCAA.com
