Just set a channels pass and you can record all you have access too. No need for using Eplus for this.
@m0ngr31 has this issue with MSG and Gotham Sports been looked into? Because in the past few weeks, I've had all of my recordings fail when trying to record MSGSN. It keeps saying Failed to start stream... Could not fetch playlist. I could get MSG to work though right now, just not MSGSN. I'm using the linear channels and just upgraded to the latest version v4.8 and refreshed my Gotham Sports login credentials and TVE token and rebuilt EPG. Still, no luck. The YES network is working well as well.
That's fine for the games, but not the exclusive linear channels.
How do I install EPlusTV (I'm not very familiar with GitHub). I don't see an install or .exe file there? I appreciate the help.
ie. After I install Channels, How do I get EplusTV and add it to Channels?
Scroll way up to the top of this thread and ready away...
Before posting I did go to the top and read and read. Some things I'm just missing/need help with:
  • First I didn't know how to "install" EplayTV and the link to Docker .
  • I've since found a docker for windows .exe (via Google) that I installed. With that installed, I foudn ePlusTV and clicked "pull"
  • Now I see that there is code - e.g."docker run -p 8000:8000 -v config_dir:/app/config m0ngr31/eplustv" that I'm supposed to run in Docker. How do I do that? Where do I type that in to?
  • Once I do that, what do I put in ChannelsDVR Custom Channels setup: Stream Format? Source URL/Text or File? other Source field? Options fields? Guide data fields?
    thanks!
It looks like all of the March Madness games that would normally be available via cbssports.com are now only on the March Madness website. If I select the Arkansas vs. Kansas game, it redirects me to the stream on the NCAA website. These events do not populate into EplusTV via CBS Sports or Paramount+.
Source URL: http://[your-ip-here]:8000/channels.m3u
Guide data field: http://[your-ip-here]:8000/xmltv.xml
It's been a while since I used Docker desktop but I believe it has a built-in terminal. If you have what looks like a play button next to the container, I think that should start it.
thanks that was helpful. I found a "terminal" button in Docker Desktop. I entered the code, and got this response:
[email protected] start
ts-node -r tsconfig-paths/register index.tsx
=== E+TV v4.8.0 starting ===
Server started on port 8000
=== Getting events ===
=== Done getting events ===
=== Building the schedule ===
=== Done building the schedule ===
That seems good, now it seems that I'm supposed to run the following from my webbrowser(?). I'm guessing that is the ip for EplusTV? How do I find out what the eplusTV ip is?
http://:8000
Use the ip of the machine docker is running on. If you are using the same machine as your dvr server you can find the ip on the settings, status, net section. Just add :8000 to the end. It will be something like 192.168.1.150:8000
Thanks - GetChannels DVR says: 2 interfaces: 192.168.1.154, 172.31.0.1. I entered both in my web browser with :8000 at the end e.g. http://192.168.1.154:8000
And it says: " This site can’t be reached. 192.168.1.154 refused to connect.
Update: Does Docker "go to sleep" or something. As I had previously successfully run "docker run -p 8000:8000 -v config_dir:/app/config m0ngr31/eplustv" but the http://192.168.1.154:8000 didn't work (as noted above). I decided to rerun that in docker and now it works! I'm entering my subscription info ! THX
It shouldn’t but I don’t really know much about docker running on windows. I would also suggest you install a docker container called “Portainer” it helps to visualize your docker environment and will help with other channels tools like Olivetin and OliveTin’s project one click.
@m0ngr31 is there a way to get SNY as a linear channel after adding to the MLB app? My previous setup is broken now that SNY isn't streaming on its own website anymore.
AFAIK, MLB just does the streaming for games, not their linear feed. If they have an app somewhere that does the linear stream I can look at adding that if you let me borrow your creds
Do you know what zone you're in for MSG? Maybe I missed a mapping there or something
Hello @m0ngr31 , first off thank you for building and running this project. I could use some help when you have a moment. I got as far as being able to get the ESPN+ streams working. But no matter what settings I change, my feed will cut out after 1-5 minutes. I spent all weekend trying to troubleshoot and am at a loss.
Additionally, I have paramount+ and thought I authenticated properly on the eplustv admin/setup screen but I didn't see any feeds for NCAA games this past weekend. Is that for NFL only perhaps?
Thanks in advance for any guidance.
Can you be very specific when you say "cut out"? What device are you using?
It happens on all my devices. On my pc where I host my server/docker. Same thing happens on my firestick or laptop. I get a feed for 1-5 minutes and then it dies. I get a transcoding error. I have to press play to get it going again. Happens on every channel. I have my server set up to feed original quality, direct. Hardware encoding.
Ok, reason I ask is I am having a similar but apparently different issue except mine is about "Device Disk Full"
