Yeah still happening today, guess I'll bounce it. Only one of the channels for each dupe work so it's busted for recording in this state. Looks like it's just fs1.
Updated to latest and bounced it, still seeing dupes across some Fox events:
2025-04-17 17:33:48 === E+TV v4.9.2 starting ===
2025-04-17 17:33:48 Using START_CHANNEL variable is no longer needed. Please use the UI going forward
2025-04-17 17:33:48 Using NUM_OF_CHANNELS variable is no longer needed. Please use the UI going forward
2025-04-17 17:33:49 HTTP server started on port 8000
2025-04-17 17:33:49 === Getting events ===
2025-04-17 17:33:49 Looking for FOX Sports events...
2025-04-17 17:33:49 Looking for MLB.tv events...
2025-04-17 17:33:49 Looking for Victory+ events...
2025-04-17 17:33:49 Looking for NFL events...
2025-04-17 17:33:50 Adding event: Home Feed - Medicine Hat at Prince Albert - Game 4
2025-04-17 17:33:50 Adding event: Home Feed - Lethbridge at Calgary - Game 5
2025-04-17 17:33:50 Adding event: Home Feed - Portland at Everett - Game 5
2025-04-17 17:33:50 Adding event: Home Feed - Spokane at Victoria - Game 4
2025-04-17 17:33:50 Adding event: First Things First
2025-04-17 17:33:50 Adding event: Speak
2025-04-17 17:33:50 Adding event: Royals at Tigers
2025-04-17 17:33:50 Adding event: MLB on FS1 Postgame
2025-04-17 17:33:50 Adding event: Breakfast Ball
2025-04-17 17:33:50 Adding event: The Facility
2025-04-17 17:33:50 Adding event: The Herd With Colin Cowherd
2025-04-17 17:33:50 Adding event: NASCAR Craftsman Truck Series - Black's Tire 200
2025-04-17 17:33:50 Adding event: College Softball - Texas Tech at Arizona
2025-04-17 17:33:50 Adding event: Horse Racing - America's Day At the Races
2025-04-17 17:33:50 Adding event: NRL Rugby - Dolphins vs. Melbourne Storm
2025-04-17 17:33:50 Adding event: NASCAR Craftsman Truck Series - Black's Tire 200, Qualifying
2025-04-17 17:33:50 Adding event: Canadian Premier League - Cavalry FC vs. Vancouver FC
2025-04-17 17:33:50 Adding event: Women's College Lacrosse - Michigan at Northwestern
2025-04-17 17:33:50 Adding event: Men's College Volleyball - USC at UCLA
2025-04-17 17:33:50 Adding event: Seattle Mariners @ Cincinnati Reds - AWAY
2025-04-17 17:33:50 Adding event: Seattle Mariners @ Cincinnati Reds - HOME
2025-04-17 17:33:50 === Done getting events ===
2025-04-17 17:33:50 === Building the schedule ===
2025-04-17 17:33:50 Scheduling event: Horse Racing - America's Day At the Races - FS2
2025-04-17 17:33:50 Scheduling event: First Things First - FS1
2025-04-17 17:33:50 Scheduling event: Speak - FS1
2025-04-17 17:33:50 Scheduling event: Royals at Tigers - FS1
2025-04-17 17:33:50 Scheduling event: Women's College Lacrosse - Michigan at Northwestern - BTN
2025-04-17 17:33:50 Scheduling event: Hockey - Home Feed - Medicine Hat at Prince Albert - Game 4 - Victory+
2025-04-17 17:33:50 Scheduling event: MLB on FS1 Postgame - FS1
2025-04-17 17:33:50 Scheduling event: Men's College Volleyball - USC at UCLA - BTN
2025-04-17 17:33:50 Scheduling event: NRL Rugby - Dolphins vs. Melbourne Storm - FS2
2025-04-17 17:33:50 Scheduling event: Breakfast Ball - FS1
2025-04-17 17:33:50 Scheduling event: The Facility - FS1
2025-04-17 17:33:50 Scheduling event: The Herd With Colin Cowherd - FS1
2025-04-17 17:33:50 Scheduling event: NASCAR Craftsman Truck Series - Black's Tire 200, Qualifying - FS2
2025-04-17 17:33:50 Scheduling event: NASCAR Craftsman Truck Series - Black's Tire 200 - FS1
2025-04-17 17:33:50 Scheduling event: Canadian Premier League - Cavalry FC vs. Vancouver FC - FS2
2025-04-17 17:33:50 Scheduling event: College Softball - Texas Tech at Arizona - FS1
2025-04-17 17:33:50 Scheduling event: Hockey - Home Feed - Lethbridge at Calgary - Game 5 - Victory+
2025-04-17 17:33:50 Scheduling event: Hockey - Home Feed - Portland at Everett - Game 5 - Victory+
2025-04-17 17:33:50 Scheduling event: Hockey - Home Feed - Spokane at Victoria - Game 4 - Victory+
2025-04-17 17:33:50 Scheduled 26 entries...
2025-04-17 17:33:50 === Done building the schedule ===
Okay yeah I was able to confirm the issue - probably an issue on linear channels, but it doesn't matter if those are double added multiple times or not because of how the xmltv stuff grabs the data...
I have a fix going up now for v4.9.3.
I'm not removing the bad entries, just fixing them, so you'll have those duplicates scheduled still but you can rebuild your EPG in the UI and reload the xmltv file in Channels (you'll need to do this one either way)
Thanks man! This continues to be one of the best containers out there for channels. Y'all are awesome.
Looks like Fox playback is broken now, can't get content when trying to stream an FS1 show.
TypeError: Cannot read properties of undefined (reading 'trackingData')
at FoxHandler.<anonymous> (/app/services/fox-handler.ts:341:20)
at Generator.next (<anonymous>)
at fulfilled (/app/services/fox-handler.ts:5:58)
at processTicksAndRejections (node:internal/process/task_queues:95:5)
Could not get stream information!
Failed to parse the stream
@m0ngr31, confirmed the same as above and here, opened up an issue for you with my logs and info, too:
Yeah, looks like FOX is slowly upgrading their platform or something... Changing stuff around. I need to update the integration to have parity with the app, but playback is working now with v4.9.4
Not sure if allowed to ask here BUT ill go for it
Finally dabbled into Docker Desktop only for EplusTV for now....Just to pull the Gotham Sports channels (mainly YES Network) Not sure how but i got it all set up etc ESPN works fine BUT the Gotham channels seem very very picky when trying to use my TV provider authentication. Also needed to Re-authenticate 2 days later?? Is this normal and what is the sure fire way to properly Re-Authenticate ??
Is it possible to add the Stars first round games on Victory+? They are not showing up in the guide.
Yeah looks like they are using a different seriesId for the playoffs for some reason. Something to keep an eye out for on the other teams going forward I suppose.
New version should land in a few minutes
It should be refreshing the tokens automatically. Are leaving the container running or shutting it down when not in use? Is there token errors in the logs?
Many thanks. FWIW, this is only an issue for the first round as that's all the local/regional broadcasters are allowed to show.
And it might only be 3 more games
That's a distinct possibility the way the Stars have been playing the last 3 weeks. Not having Robo and Miro will also not make it easy to carry on the nearly annual tradition of beating the Avs in the playofs.
So I have no idea whats going on BUT it has been aok since i made this post ...... Its running on my dedicated Channels DVR PC so i leave it all running etc.....Ill see how long it goes error free BUT I must say this is Awesome I dropped YES into my guides etc and its seemless
Is there any possibility of adding MASN now that they are offering direct to consumer streaming subscriptions?
how do i make the eplustv app auto start after restarting pc/docker desktop???
Maybe i got it restarting now upon a reboot....googled it and found a script to run in the Docker terminal The whole Docker EplusTV thing is alien to me BUT when its working its so nice.
If you want to DM me your creds I can look at getting it added
Thanks
