Can confirm, Prime linked to a NFL.com account still works for TNF.
yeah. that's the one
NESN is confirmed drm though right. Will it be removed in new build?
I was able to rip the mountain west/spectrum sports Hawaii game m3u8 but haven't figured out how to consistently pull it. I did a logcat
I have noticed an odd issue.
When using ESPN with Channels, I normally wil get the ESPN feeds. I went to tune in this afternoon and had the service unavailalbe.
I went to see if it crashed and it turns out i have to click the reset active playing channels to get ESPN back and working.
I have to do the option every couple of days.
Hey all, Fox Soccer channel is not working for me, is it working for you?
It is not working here either.
Thanks. I love this plugin, and I hate nitpicking because it works amazing but thanks for the feedback. Would love to contribute monthly to this project. I also noticed fox tokens last a month before re-login. is it possible to do this automatically or is it manual for now without some kind of mouse click script or python puppeteer magic.
I haven't been able to test Fox Soccer Plus since the recent updates because I don't have access.
If either of you can loan me credentials via PM, I can probably get it back quickly.
I think my credentials are used up for now, I activated a few tokens with a vpn and I think I am on a cooloff
I did mention Spectrum Sports - Hawaii in dm. It might be promising.
Itβs all there on the GitHub page in the ReadMe section.
Link in post #1
I figured out how to get foxone streams, basically have a script to run mouse mover to grab new m3u8 every day , ffmpeg copy to a m3u8 on hdd. suboptimal, but it works. also got local news working this way. Hopefully there is a better way to do it, maybe with playwright
(post deleted by author)
Hmm. Mine died after 2 days. and index_1.m3u8 is better quality
I attempted to write code to snatch the m3u8 out, but nothing worked so far.
I think a sniffer running would work, not sure if vlcbridge would work, I still dont know how it works.
i tried using fox one with my fubo log in and it said provider not supported.b b Not sure if being on essentials makes a difference.
If you do index.m38u instead of index_1 through index_7 it appears to change the stream quality automatically based on connection up to the max of 720P.
This feels off-topic unless Tony integrates it into EPlusTV, so this is the last I will discuss it here.
Yes especially since it dies after 2 days.
As a fan, of Channels and all the great features, i'm all about getting the best out of my products and services.
Thanks for the link!
ESPN Deportes
Fox Deportes
I don't speak spanish but these are channels available. I grabbed m3u8 from foxone, testint longevity but could these be added in future update? Sometimes they play soccer and stuff if nothing is on.
tony if you dont have these we can do credential and get the Fox soccer channel working again.
