ok so will be better for chrome capture then or possibly see if playlist manager can help. was trying to find a way to grab the stream day of, use the livesportsontv to scrape guide data, similar to what I am doing for peacock/HBOmax+
Anyone else have issues with ESPN TVE login? Where it should be giving me an authorization code it says "undefined"
I don't have a problem witih login but after 3 or 4 days ESPN will stop working correctly. I have yet to nail down the problem.
Is there a way to refresh docker perhaps every day or 2 days?
I used fox one and grabbed m3u8 and apparently their streams don't expire it seems
how does it keep notifying that you are still valid?
If you say it doesn't expire i might be willing to put it through slm and get a good copy of my fox affiliate.
definitly worth while. i just want my local but if i can at least have access to fs1 and 2 i'm in.
I keep using the m3u8 and it works , it doesnt expire for me.
For the next mountain west / spectrum sports Hawaii game if I do a logcat do you think we can get data that will help to pull those exclusive app games into the docker?
I doubt that I would have time to do it. I'm not familiar with the Mountain West provider in E+TV, and if it's delivered through a different app, it might be the coding equivalent of creating a whole new provider.
Thanks just thought I would ask. So is it true ESPN is limiting concurrent streams to 3 or does this not apply?
This doesn't apply.
tony I hate to ask for another, but do you think you could add support for Zeam sports?
https://zeam.com/events/
If not I will try to add support in another addon.
That one looks easy enough. Don't know when I'll get to it, but I hope to catch up soon.
Edit: there are ads inserted in the stream, though. Don't know how that will affect different playback clients like Channels.
I just did this where i simply reboot my channels pc everyday at 4pm (not home) docker is set to start with pc
I restart this container every day using restart-notifier after seeing @babsonnexus recommend it earlier in this thread: ESPN+ & FOX Sports with Custom Channels via EPlusTV - #2474 by babsonnexus
Just a reminder for this time of year. I tried this with Playlist Manager last night and got the same issue; no available streams for the Prime Video Twitch channel that are not DRM protected. As such, if you want to integrate this, you'll need to use CC4C or AH4C.
Or you can do what I do recording the replay on NFL Network:
I am subscribed to ESPN through MyDisney. I do not see that as a provider in the list on the EplusTV main page. It has ESPN as an option, but that does not work. It sends me to the Provider login on the ESPN page. When I use ESPN on the web (or TV) I do not have to choose a provider. I simply login direct with my MyDisney account. There is a "Walt Disney Company" option in one Provider list, but that is an employee account. MYDisney logins do not work there.
I can get all 200 channels on ChannelsDVR but no programming shows up. Is the lack of provider sign-in causing this? Automatic Channels did not provide anything either.
ESPN Ultimate support hasn't been added yet, but it's being worked on.
I believe others have reported that the ESPN+ events should work with your login info, just not the linear networks yet.
So prime no longer works for this addon?
I assume when you mention ESPN Ultimate you are actually referring to ESPN Unlimited maybe?
As far as I know, the Prime regular integration still works (don't have Prime, couldn't tell you). This was specific to trying to get the Prime Twitch stream.
