please delete these links or op please delete, this can be seen as circumventing TOS/ could get channels in trouble.
@GTFan are you still missing the "NFL - " prefix on some event titles? I am unable to recreate. I verified that all NFL provider events in EPlusTV are given a "sport" value of "NFL", and EPlusTV prepends this sport value when scheduling all non-linear events. This has not changed since last year.
I don't have local games through this, only TNF, but they should all work the same, unless they are coming through on a linear channel (in this case, NFL Network, NFL RedZone, or NFL Channel).
No they're all working now like they did before, it was just that first weekend local Fox game for some reason. Everything since has had the 'NFL -' prefix. I get all the locals plus Prime.
Just noticed that an MLB game on FS1 today didn't have the 'MLB -' prefix though, just says Guardians vs. Tigers I don't record these, just noticed it in guide. Not sure if they're supposed to have it.
That could have been caused by the Fox Sports EPG changes this summer. I will take a look!
let me know if you need my credentials to add Fox Soccer Plus and Fox Deportes
Yes, you can PM me.
Nevermind, I dont have that channel apparently, my bad. I do have Deportes though, do you have that on your end?
I don’t have access to Deportes. I don’t think EPlusTV was ever set up for that channel, but I could give it a try if you loan it.
Great project @tonywagner . I just read about this in an article from Jared Newman. I applogize if this has already been discussed but I'm wondering if the dedicated streaming service for the Denver Nuggets and Colorado Avalanche called Altitude+ could be added. They have a streaming service but they don't have any DVR capabilities if you are just a subscriber and don't have it with your TV Provider.
Are we able to use this to auth to the new Fox One service and pull in all that is available there with our TV Provider login?
The fox one stuff isn't available through the project.
I was able to pull in my local FOX station sporting events ONLY using my YTTV credentials, but it will not give you a local FOX station linear channel (non sports programming).
The rest of the sports channels I sub to with YTTV also appeared.
ESPN channels, FS1, FS2, B1G Network and FOX Soccer Plus.
Some users think that because they can sub to Fox One, that it's a TVE provider. It's not. Just like Discovery Networks (multiple channels) is not a TVE provider.
Thanks. Makes sense. YTTV TVE pulls in my FS1, FS2 and B1G but not my local FOX in DFW. It shows the channel but the URL seems to be borked and it hides it. Interestingly E+TV did pull in the local FOX channel last night for the BIG 10 football game that was on using the regular Fox Sports integration. Guess I will see if it pulls in more of the local FOX sporting events this weekend. If not it may be time to buy the cheapest HD Homerun. That would give me NBC as well which is also not pulled in by my YTTV sub.
I have been unable to confirm FOX Soccer Plus since the recent updates. Do you see FOX Soccer Plus events in your EPlusTV XML data, and can you play it from the EPlusTV M3U file?
Flagship FOX sporting events are indeed supported by E+TV, via the Fox Sports provider.
Yeah from what I've seen you get all of your local channel Fox sports, nothing's been missing.
Texas Tech vs Utah 4K available now (Saturday Noon Eastern)
Thanks @tonywagner
Yep same here! Thanks! fyi..the 4k in the new Channels multiview was struggling for me. Looks great in full screen though.
I had it going for about two minutes, and then it flipped back to HD. I'm using an M2 Mac mini and 300 Mbps up and down internet.
EDIT: I see what happened. The commercials are HD, but the game is 4K
Right. Mine just stops working after a bit so not a good solution until it's fixed.
