Finding that I need to restart the EplusTV container often.....I'm really only pulling in Gotham linear channels ( ESPN as well used for testing)I attached a snip of the log files Before i restart the container which fixes it
2025-09-27 05:59:13
Adding event: Talkin' Yanks
2025-09-27 05:59:13
Adding event: DraftKings Casino Report
2025-09-27 05:59:13
Adding event: MLB Baseball
2025-09-27 05:59:13
Adding event: UFC Live: Ulberg vs. Reyes
2025-09-27 05:59:13
=== Done getting events ===
2025-09-27 05:59:13
=== Building the schedule ===
2025-09-27 05:59:13
=== Done building the schedule ===
2025-09-27 05:59:14
Refreshing Gotham auth token
2025-09-27 09:59:10
=== Getting events ===
2025-09-27 09:59:10
Looking for Gotham events...
2025-09-27 09:59:10
Looking for ESPN events
2025-09-27 09:59:11
Adding event: Paid Programming
2025-09-27 09:59:11
2025-09-27 09:59:11
2025-09-27 09:59:11
2025-09-27 09:59:11
2025-09-27 09:59:11
2025-09-27 09:59:11
Adding event: Bronx Buds
2025-09-27 09:59:11
2025-09-27 09:59:11
2025-09-27 09:59:11
2025-09-27 10:29:12
2025-09-27 10:50:16
Could not get a playlist for channel #364. Please make sure there is an event scheduled and you have access to it.
2025-09-27 10:50:16
2025-09-27 10:50:17
2025-09-27 10:50:17
2025-09-27 10:50:18
I hate to jinx it but I've been watching the Fox 4K USC vs Illinois game and it's been rock solid. No longer dropping at commercials. Commercials are 1080 while the game broadcast is 4K.
@GTFan Are you able to test?
Can confirm. Native Resolution flips between 1920x1080 to 3480x2160 with just a short black screen for me.
No I'm watching a different game and using multiview, I'll have to try it some other day.
Lol I just enabled 4K and tried to watch in multiview, bad idea! ATV 4K 2nd gen can't handle that with even one other channel going, the stream was unwatchable and almost immediately crashed the channels app when I added it to a three channel setup.
I did try it briefly after the app crashed and I restarted, streams fine but it did before. Can't really watch it on its own for long though because I'm watching my other game, which just happens to be GT cuz I'm GTFan!
I'm getting a lot of interruptions in my log (discontinuity_detected=1 transport_errors=0) but watching it looks fine so maybe that's expected with the changes in resolution from 1920x1080 to 3480x2160
Not sure why but my tokens seem to not be doing a baton handoff quickly. after about 3 minutes my espn3 streams always fail and work if I reload I havent figured out any way around this. I think espn works but just not espn3/+
It seems the token expires quickly maybe a token handoff needs to change frequency? ESPN linear doesnt do this only espn3 and +
I get 403 forbidden
I am on the latest build
Is anyone else having this issue
I did jinx it. It disconnected a few times but was much more robust than last week. Not sure what's going on...
Bummer. I know it worked last year but I only did recordings of the games then because I didn't have multiview, I don't think I ever saw a problem with the recordings though.
Now I'm using multiview every weekend because it's much more fun.
Did y'all have issues with ESPN 3? Non linear ESPN
Also there is ESPN abc and ESPN 3 that play same game. Can you have both options
Lastly, could ESPN Deportes also be added linear and perhaps certain Eplus+games be reserved for certain channels numbers? Thanks for the responses
getting the following error on yes on gotham sports:
channels dvr reports the following:
2025/09/27 21:42:31.666822 [ERR] Could not start stream for M3U-epluslinear ch771 Yes Network: M3U: Could not fetch playlist from localhost:8000: GET: http://localhost:8000/channels/364.m3u8: 404
Not Found
edit:
restarting eplustv fixes it.
I posted the same issue a few posts back and yes a container restart fixes it
How do you get the channels to not freeze after 1 minute? Its doing it on all my channels, no one else having this issue?
Maybe it needs to refresh auth key more often? Do I need to just totally redo my tokens
No issues here. Just tested with Gotham channels as well and they are working correctly.
I do restart my container daily as a maintenance task that is tied back to when things were not updated for a bit.
I would probably give this a try and hope that it solves your issue.
It seems all the channels are working, just ESPN3 is having issues, I noticed ESPN shows ESPN-ABC and ESPN3 (is it the same m3u8 on espn.com) they have two different links. Waiting for another ESPN3 to test. I also had docker crash had to restart, is there something we can program to keep the docker up and running ?
Tony:
My E+ channels are working, however the guide only shows the network name, and no info about hte games/shows. I've rebuilt the EPG in E+TV and in CDVR I've reloaded the M3U and refreshed the XMLTV but same issue.
Any idea?
thanks!
Make sure the linear channels are mapped in Sources-Manage Lineup
yep, that was it, thanks!
A few days ago, Fox Soccer Plus and Fox Deportes started working again, but now Fox Soccer is gone again. It shows as checked on the Eplus local page, but does not show up in the linear channel source in CHDVR. I've reset active playing channels on the local page and reloaded and disabled/reenabled on the source in Channels. Anyone else having this issue?
Deportes working here
