Get it from OliveTin for Channels OliveTin for Channels: An Interface for Misc Channels DVR Scripts & Tricks - #247 by bnhf
version: '3.9'
services:
# GitHub home for this project with setup instructions: https://github.com/m0ngr31/EPlusTV
# Docker Hub home for this project: https://hub.docker.com/r/m0ngr31/eplustv
eplustv:
image: m0ngr31/eplustv:latest
ports:
- 8185:8000 # For use with Portainer this port is being mapped to 8185, as Portainer uses port 8000
environment:
- START_CHANNEL=${START_CHANNEL} # What the first channel number should be.
- NUM_OF_CHANNELS=${NUM_OF_CHANNELS} # How many channels to create? This is dependent on the networks you are using. A good number to start with is >= 150 if you are using ESPN+.
- USE_LINEAR=${USE_LINEAR} # If you are using linear channels like ESPN, FS1, ect., and want those events on their own dedicated channels.
- PROXY_SEGMENTS=${PROXY_SEGMENTS} # Proxy keyed *.ts files.
- PUID=${PUID} # Current user ID. Use if you have permission issues. Needs to be combined with PGID.
- PGID=${PGID} # Current group ID. Use if you have permission issues. Needs to be combined with PUID.
- MAX_RESOLUTION=${MAX_RESOLUTION} # Max resolution to use. Valid options are UHD/HDR, UHD/SDR, 1080p, 720p, and 540p (Some providers don't offer 4K or 1080p and will attempt to play the highest framerate available for selected resolution).
- ESPNPLUS={ESPNPLUS} # Set to false if you only want events that come from your TV provider
- ESPN=${ESPN} # ESPN: Set if your TV provider supports it
- ESPN2=${ESPN2} # ESPN2: Set if your TV provider supports it
- ESPN3=${ESPN3} # ESPN3: Set if your TV provider supports it
- ESPNU=${ESPNU} # ESPNU: Set if your TV provider supports it
- SEC=${SEC} # SEC Network: Set if your TV provider supports it
- SECPLUS=${SECPLUS} # SEC Network+: Set if your TV provider supports it
- ACCN=${ACCN} # ACCN: Set if your TV provider supports it
- ACCNX=${ACCNX} # ACCNX: Set if your TV provider supports it
- LONGHORN=${LONGHORN} # Longhorn Network: Set if your TV provider supports it
- FOXSPORTS=${FOXSPORTS} # Set if your TV provider supports it
- FOXSPORTS_ALLOW_REPLAYS=${FOXSPORTS_ALLOW_REPLAYS} # If you would like to schedule events that aren't live
- MLBTV=${MLBTV} # Set if you would like to use MLB.tv
- MLBTV_USER=${MLBTV_USER} # MLB.tv Username
- MLBTV_PASS=${MLBTV_PASS} # MLB.tv Password
- MLBTV_ONLY_FREE=${MLBTV_ONLY_FREE} # Only schedule free games
volumes:
- /data/eplustv:/app/config
# Default Environment variables can be found below under stderr -- copy and paste into Portainer-Stacks Environment variables section in Advanced mode
stderr
- START_CHANNEL=1
- NUM_OF_CHANNELS=150
- USE_LINEAR=false
- PROXY_SEGMENTS=false
- PUID=1000
- PGID=1000
- MAX_RESOLUTION=uhd/sdr
- ESPNPLUS=true
- ESPN=false
- ESPN2=false
- ESPN3=false
- ESPNU=false
- SEC=false
- SECPLUS=false
- ACCN=false
- ACCNX=false
- LONGHORN=false
- FOXSPORTS=false
- FOXSPORTS_ALLOW_REPLAYS=false
- MLBTV=false
- MLBTV_USER=false
- MLBTV_PASS=false
- MLBTV_ONLY_FREE=false
