Instead of blindly changing things you need to find out what error you're getting and what it means.
Then troubleshoot.
The compose file worked and ran it but now when I type my ip with 8090 I get this
The connection was reset
The connection to the server was reset while the page was loading.
The site could be temporarily unavailable or too busy. Try again in a few moments.
If you are unable to load any pages, check your computer’s network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the web.
What exactly are you "typing in" and where are you typing it?
On my browser I am typing the ip of the nas followed by the :8090
If the docker container is running. look at the container log.
I am getting 404 not found on that ip
How about ip:8090/channels.m3u
I'll let someone else help. I don't run that docker.
It looks like it worked it downloaded a m3u file, but for the epg what do I use?
It's in the instructions
Ip:8090/xmltv.xml
You guys are awesome thank you for helping me I really appreciate it!!!!!
Are there instructions for getting this up and running in Channels in a VMware Virtual machine? I don't have time to learn Docker as mentioned in the github directions. My Channels Server is a Windows 10 ESXi 8 VM.
If you learned ESXi you can learn docker easily.
Better to go that route then asking for help for your one-off config.
I'm all-in on VMware and have negative time available to learn something new.
I'll have to come back to this again in a few months if there aren't any guides.
Thank you
Setting up a VM to run this is like 1000% more effort and energy to run this than just firing up a docker container
I installed Docker on my ESXi Win10 VM. I don't have ESPN+ but I do have Fox Sports through YTTV. What's the install command to get Fox Sports? The command in the guide gives me errors.
docker run -p 8000:8000 -v config_dir:/app/config -e PUID=$(id -u $USER) -e PGID=$(id -g $USER) m0ngr31/eplustv
ERROR: "Unknown shorthand flag: 'g' in -g"
Those commands to get uid and gid are Linux -- and you probably installed Docker Desktop. What backend is Docker Desktop using with your setup?
